E-Class (W213) 2016 - 2023
2017 E400 Wagon tail light replacement
Old Feb 4, 2023 | 03:29 PM
Mclosefh's Avatar
S213
New to the forum. Got a dashboard msg that right rear taillight and backup lights not working. Found that the inner (on liftgate) light assembly was missing the running light LEDs, and all of the backup light leds. Checked the left side and only 2 segment of the backup leds were working. On both outer assemblies, none of the white backup leds were working.
I could only find Youtube vids for the 2106 models related to removing the inner lift gate trim, and the 2017 model is different.
First question is how to remove the trim on the lift gate?
Second question - any ideas on why all of these assemblies are malfunctioning?
Old Feb 4, 2023 | 04:57 PM
dbldpr's Avatar
Veteran: Navy
Welcome hopefully someone here will know how to do the work, Good luck
Old Feb 4, 2023 | 09:56 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W213 forum...
Old Feb 5, 2023 | 07:32 AM
Bfgslkman's Avatar
From: Northern Germany and sometimes Southern Germany
Mercedes E220d AMG Line Estate (S213) and Mercedes E220d AMG Line Cabriolet (A238)
Prize the cover off the pull down handle, remove the screws and then prize out the cover from the tailgate. No screws just clipped in around the outside.
Old Feb 5, 2023 | 03:28 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Mar 9, 2023 | 01:24 PM
Mclosefh's Avatar
S213
Thanks, got the trim pieces off easily.
