E-Class (W213) 2016 - 2023
Wheel Offset for wagon
Old Mar 21, 2023 | 06:08 PM
Novasteve's Avatar
E450 wagon
Howdy all,
I have a 2020 e450 wagon and want to switch out the wheels. Looking at some older Mercedes wheels, 19x8 38ET. I know stock offset is 43 and have read that chassis and suspension on all E class are the same so anything that fits on E43 should fit any other E class? Anyone have a w213/s213 running aftermarket or non factory wheels want to chime in?
TYIA!!
Old Apr 21, 2023 | 10:09 AM
Wagonfan1's Avatar
2021 e450 All Terrain
Hello Novasteve:
Where did you find the ET43 spec? I use this site that collects multi-vehicle data and it shows 38ET for the 19”x8” OEM/NA (USA).
https://www.wheel-size.com/size/merc...-terrain/2021/
Old Apr 21, 2023 | 10:52 AM
Novasteve's Avatar
E450 wagon
Originally Posted by Wagonfan1
Hello Novasteve:
we are looking at two different cars. I'm looking at the standard F450 wagon. You are looking at the all-terrain version.
Old Apr 21, 2023 | 03:59 PM
Wagonfan1's Avatar
I now see you have MY 2020 not 2021. Missed that!
FYI- try to retain ET offset in front close to factory as too much deviation (+/- 2-3) alters the scrub radius, which then changes the factory steering response. Rears ET not as sensitive to change if you decide to go wider in rear. Good Luck.
