E-Class (W213) 2016 - 2023
2017 S213 E-Class - Battery Replacement - 'Reset'?
Old Apr 20, 2023 | 06:22 PM
alt123's Avatar
C220 2008 W204
Hi all,
Going to replace starter battery in my 2017 S213 E-Class (2.0 Diesel Estate) - I see people online about having to 'reset' when new battery installed.
Is this true?
I had the starter battery disconnected for over a week a while back and when I reconnected, all was fine! (I know there's an aux battery on these cars).
Some people stating online that there's a diagnostic reset procedure to reset alternator output.
Any ideas? Thanks all
Old Apr 21, 2023 | 02:58 AM
Bfgslkman's Avatar
From: Northern Germany and sometimes Southern Germany
Mercedes E220d AMG Line Estate (S213) and Mercedes E220d AMG Line Cabriolet (A238)
You can just replace but the car will be trying to charge it at the level it needed to sustain the old battery. Ideally you need to code the BMS module to tell it you've got a new battery and it will then turn down the "wick" of how much current it supplies. Takes about 2 mins to code, but suspect you'd get a small bill from a garage for doing it.
Old Apr 25, 2023 | 01:43 PM
alt123's Avatar
C220 2008 W204
Many thanks - Will check with a mechanic friend. He has decent quality diagnostics for Land Rover etc. - Are the diagnostics to reset the BMS on Merc, Merc specific?
Old Apr 30, 2023 | 07:11 PM
W205C43PFL's Avatar
Yes, you need to do it in Xentry Diagnostics/Star
Old May 2, 2023 | 10:10 AM
Mago 51's Avatar
Merc. S-213 220d / Jag XJ-40 / Jag X-Type Estate
Hi folks,
I've heard that a reset was due on BMW and others, but not on Mercs, at least not the W213, which was plug & play?. But reading your comments, now the doubt pops up.
Mine is fine for the moment, but better to be sure, when the time comes. Thx.
Old May 2, 2023 | 01:20 PM
Diesel Benz's Avatar
The latest MBs have this diagnostics feature to reset adaptation data after a battery change. I have not changed the battery myself and have not tried without reset but I'm sure the car works OK even if this reset is neglected. The reset just helps the car to adapt to the new battery immediately. Without reset it takes a bit of time until the car makes the best out of the battery (as designed). For example the car might charge the battery full while it normally leaves some capacity for recuperation. Nothing serious if energy recuperation is lost.
Old May 3, 2023 | 04:29 AM
Mago 51's Avatar
ok, as always, very grateful.
Old May 3, 2023 | 05:48 PM
W205C43PFL's Avatar
Yup sums it up but I am not sure if the car will actually learn overtime like you mentioned, hopefully you are right for those don't have access to star.
Old May 4, 2023 | 09:57 AM
SpeedracerZ's Avatar
2018 E43
I changed my battery several months ago without doing the reset procedure and have had no issues. The start-stop functionality is working again so the car appears to know there is a new battery.
Old May 4, 2023 | 06:56 PM
OTEKAJ's Avatar
2018 e400
Just replaced the battery on my 2018 E400, no issues, no reset required, straight swap.
Old May 9, 2023 | 04:42 PM
W205C43PFL's Avatar
Good to hear
Old May 9, 2023 | 04:57 PM
W205C43PFL's Avatar
Good to hear
Old May 17, 2023 | 06:48 AM
mickhoog's Avatar
W213 Night Edition 220d. (ML250 SLK350AMG)
Thanks to the posters that have done a straight swap.
I am using the exact same Varta battery and I was worried I would have to do some reset etc. So I am going to just do the straight swap.
Cheers
Old May 17, 2023 | 07:12 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by Mago 51
Hi folks,
I replaced two batteries each (main and aux) on a W166 MB and G01 BMW with no reset, no errors, all good.
Straight swap on both cars.
Old May 20, 2023 | 06:18 AM
Bfgslkman's Avatar
As you say you do not have to do a reset, but you should do a reset. The anology is turning down the tap to slow down the flow of water (in this case the amount of charge coming from the alternator), when you are filling a narrower bottle (in this case a new fully charged battery). You are just wasting water (or in this case electrical charge) as it will not all go in the filler neck.
Hope this anology makes sense?
Old May 23, 2023 | 10:32 AM
W205C43PFL's Avatar
Interesting analogy actually
Old May 26, 2023 | 05:40 AM
Bfgslkman's Avatar
