Who has spent more than $2k on their car in the first 7 years
I am aware of the different theories on whether or not to get the ELW from reading other posts, but now I am hoping to see some real case studies.
Your sharing is appreciated.
P. S. Reading the forums this week has really re-invigorated my enthusiasm for my car. I think I may need to apply a coat of wax today.
My car is a 2016 E350 (W212), currently with 39,000 miles. At six-years now, I have not spent a PENNEY on any item that would have been covered by an Extended Warranty. Not spent anything (either) except for maintenance (oil changes, new tires) etc.
What has been your mother's experience with her 2006 S-Class?
While awaiting further input, go wax your car... hehe.
Yeah, my car currently has around 4 layers of nano-ceramic wax coats on it, and I will probably add one more, before the onset of winter.
I've kept German cars up to 8 years w/o any major repair bills. Anything can happen, but you are better off to just take the money you'd spend on an extended warranty and put it in an account and then use it for repairs. Over time, you'll likely come out ahead if you do that with every car. You can often work out cost share with large repairs if the issues are known. For example with my previous car, an Audi RS5, I needed a transmission repair out of warranty due to a failed sensor that is known to fail eventually. The sensor itself is pretty cheap, but it required the entire transmission to be taken out and dismantled. A $6000 job at street price, but Audi USA agreed to lower the quoted price to $5000 and then do a 50/50 cost split. So, it was $2500 for me in the end. Still high yes, but much better than 6 grand. That was probably the highest out of warranty repair bill I ever had and I sold the car shortly after as I didn't feel it was a keeper after that.
From the response, or more accurately the lack thereof, I have concluded that very few have bought an ELW and more important, they are satisfied with their decision: not to get an extended warranty.
My warranty ends in December 2022: I have decided not to get an ELW.
As SuperSwiss posted, it makes zero sense to buy one until you decided at the end of the warranty period that you are going to keep the car. Even though the ELW is transferable, the increase in resale value will only be marginal and certainly no where near enough to cover the cost of the ELW.
Hope this helps.
see: https://mbworld.org/forums/e-class-w...ial-sense.html
Hope this helps.
To the $2200 you must add sales tax, in NY where I live @8.625% that is an additional $189 so the actual cost is $2389. Use of money for three years @ 5% per year, is another $358, so your actual cost is $2,747.
This is for a 36 month/75,000 miles. You have 26K miles and I have 30K. We both average less than 10K per year, so in three years you will 47K and I will have just over 52K: but the pricing is for 75K. So we would both would be paying for "over coverage".
Otherwise, normal maintenance has been the norm.
Put the money in a savings account - and if you ever need a repair there you go some money to help out.
OR use it for Down payment on next car or whatever.
I can see a dealer saying that without an ELW, that $17 in repairs (covered under warranty) would have been an actual expense... without the warranty.
Depends on how much effort you want to put in: You can go to the service department, put in the VIN and see when and what repairs were done.
BTW, I suspect the $17K was given by the salesman who does not know: The sales and service are separate so to get an accurate amount you must go to the service department.
But to tell you the truth, I bam not even as concerned about BS repairs as I bam for our W213s, but I am going to take a chance and not do the warranty I think. I am usually not a warranty person anyway, I just was starting to get scared of if I ended up with some $7k repair or something out of nowhere like one of those horror stories that I have heard.
The airbag suspension bags went faulty at 9 years and 10 months - replaced under warranty.
W213 has had $7K of work - nearly all under warranty. Failing radar sensors, faulty LED headlight, boot kick sensor. Glad I didn't have to pay. One windscreen - genuine MB screen replaced at dealer - Insurance paid 75% (They wanted a non genuine Chinese one)
The two problems that I had:
The digital double screen started to get "smoke" effect. Replaced under the warranty, otherwise would cost me £2500 plus labour
The AdBlue hose was blocked and wasn't supplying AdBlue into the engine. Had to be fixed within 500 miles, as the car would completely shut down.
I was quoted £1200 and it was not covered by the warranty
, because the hose was rubber and not metal or plastic. Rubber hoses are not covered.Had my local mechanic to clean the hose with a pressured air. But even he said that changing the hose would be a nightmare job.
That was 2 years ago.
I have not purchased another extension, as I did have the two things fixed, which I knew that do go wrong.
Nothing else went wrong since......
Standard services and installation of the tow bar was all that I have spent on the car
And extra set of wheels with winter tyres, when we go on snowboarding holidays (but that was at a bargain of £125 for all 4).
My vote is for not buying extended warranty.
I decided to get the extended warranty through Jeff Jefferson.
Recently when I started the car and turned it off there was a screeching sound. It did not happen with auto stop/start, only starting the car and turning it off.
Took it into the dealer:
Here was the problem: there is a flap in the exhaust that opens and closes when the car is started and turned off. This is complete news to me. The mechanic tried lubricating which improved the condition but did not cure.
They had to order and install a new exhaust system.
Total cost of parts: $1300
Total labor, 4.25 hours: $900
With tax $2390.
All covered by the extended warranty.
I did not ask why it took over 4 hours to replace a muffler. I guess some of the time was figuring out what was causing the screeching noise.
Cost of the extended warranty: $2200
The original warranty ended in December 2022. The current mileage 35K
