New '23 E450 AT
New '23 E450 AT
Just got a '23 E450 wagon (now called "all terrain" but very similar to prior '20 and '14's we have owned).
Two questions for the experts here:
(1) The car has the latest MBUX and has headsup display. There appears no way to change the position of the heads up that I can find. The touch pad on the left side of the wheel allows for turning the display on and off but nothing else. That can't be right but I can't figure this out.
(2) Has anyone found a rubber mat to fit the rear cargo area? The mat from the '20 does not fit; they must have made some slight changes. I cannot find anything that is OEM or otherwise.
Thanks in advance
Thanks in advance
fju2112 (06-09-2023)
Can't answer about MBUX, since my 2019 Wagon has COMAND. However, picking it up from the dealer, they should have done a walk around with you. If the dealership isn't too far, you could go back and ask for a tutorial on the heads up controls. And, there is always the manual .
However, I purchased a rear mat from WeatherTech and found the fit and quality to be great. I'm sure they have one for the '23.
Rob in Atlanta
Rob in Atlanta
Can’t comment on the HUD, since mine does not have them. As suggested above, weatherTech is a good source for a custom-fitted mat, even though for my E-class, I have not outfitted it with one.
M. Schneider (06-09-2023)
I have a genuine MB black rubber mat in the rear cargo area. Perhaps ask your dealer as they are available.
You're welcome.
I will pull it out tomorrow morning and see if I can find a p/n on it as I will be loading up the cargo area to go to the transfer station AKA the dump!
The grey blanket (to coordinate with the Selenite/Neva grey colors) is to protect the rubber mat that protects the carpet.
The following 2 users liked this post by E430_4MATIC:
AlteMB (05-19-2023),
You're welcome.
It is p/n A2138140100. Called a boot tub, shallow, it should fit all W213 station wagon models.
https://www.mbusa.com/en/accessories.../0:A2138140100
The following 4 users liked this post by Alan Smithee:
2023 GLE450, 2021 E350 / Used to drive: 2019 E300, 2021 + 2020 GLE350, 2019 E450 Wagon(s), 2017 E300
We have the HUD in our GLE and there is no adjustment - I find the display actually a bit low - the bottom is cut off when I have the seat adjusted comfortably for me. At that seat adjustment, I cannot see the entire HUD - yet there is no height adjustment for the HUD display in the windshield. Assuming it is the same in the 213 with MBUX. (Odd because later model GM cars with the HUD have some degree of adjustment permitted.)
2021 e All Terrain, 2001 e55
Thanks in advance
Thanks in advance
The following 2 users liked this post by e55phil:
Lanzz (05-21-2023),
2023 E63s Sedan, 2020 E53 Sedan
to change the heads up display, on the steering wheel. (forgive me I am not in the car.) But as I remember, you go to the haptic button on the left-hand side in the center and press home, as if you were going to change the display on the dashboard and you scroll up, and then you get the settings for the heads up display. You can move it up and down or right and left and you can pick what appears on the screen the speed, your instant mileage, how close you are to the car in front of you and a bunch of things. This way you can move it around, depending upon how tall you are.
https://www.mbusa.com/en/accessories.../0:A2138140200
Received 2,720 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Welcome OP, here is a thread to get you started: https://mbworld.org/forums/e-class-w...questions.html
