E-Class (W213) 2016 - 2023
Misfire
Old Jul 2, 2023 | 11:54 PM
batii's Avatar
E300 2017 (W213)
Misfire
Hello, I am the owner of a Mercedes E300 2017. I encounter a problem at times when I press the gas pedal and start accelerating from a low speed. The engine light appears and the car starts to twitch. The problem ends when I turn off the car and restart it.The error codes show that there is a misfire problem in the bank2 oxygen sensor number 1. I changed the spark plug and coils.
Need your support please please .
Old Jul 7, 2023 | 07:36 PM
W205C43PFL's Avatar
What was the condition of the old spark plugs and coils, what is the mileage on your car?
Old Jul 7, 2023 | 10:28 PM
batii's Avatar
E300 2017 (W213)
The old ones were fine, but I changed them all.
70k mileage but this issue start from 55k miles
Old Jul 7, 2023 | 11:17 PM
W205C43PFL's Avatar
Is the code stored or active, any other codes from other control modules, any new codes from the same module?
Old Jul 8, 2023 | 04:16 PM
batii's Avatar
E300 2017 (W213)
sometime P0304 and sometime P0303 when stop engine and start again engine light clear , engine Hesitation or sputtering in acceleration between 2000 RPM to 4000 RPM
Old Jul 8, 2023 | 07:33 PM
W205C43PFL's Avatar
Hmmm, first time hearing about this on this engine.
@chassis Mind helping out here? Thanks.
Old Jul 8, 2023 | 07:43 PM
PeterUbers's Avatar
Is this the m274 engine? You may be misfiring for more issues than the plugs and coils. Injector ... compression issues ... cracked head etc
https://mbworld.org/forums/e-class-w...k-miles-2.html
Old Jul 8, 2023 | 07:46 PM
W205C43PFL's Avatar
Reason I asked for OP was because I don't recall cracked cylinders having those codes, maybe I just haven't came across it hence why I requested assistance from forum member chassis which he has a lot of knowledge on this subject.
Old Jul 8, 2023 | 07:50 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
If your plugs and coils are fresh and installed properly I'm guessing LSPI. Hows your oil
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jul 9, 2023 | 01:50 AM
batii's Avatar
E300 2017 (W213)
Keep changing it constantly changing it every 5000 miles ( shell helix ultra 5W40 )
Old Jul 9, 2023 | 10:16 AM
batii's Avatar
E300 2017 (W213)
Note: I encountered a problem of leakage and loosening of the outlet nut from discharge of high pressure fuel pump , I don't know if the two problems are related or not
Old Jun 25, 2024 | 10:08 AM
bluesky07734's Avatar
e300
Hi, I have 2017 E300 and has same problem. changed spark plug, coils, cleaned fuel injector but still misfired when accelerating. Could you advise me what the problem is and how to fix? Thank you.
