Picked up and test fit some new beef for the wagon!
Knock offs (EBay) but got such a good deal, I don’t care if I swap them in a year…they’re SO much better than what I had.
Tires aren’t my first choice, see statement above.
Front: 8.5” rim with 245/40/20 Pirelli P-Zero A/S
Rear: 9.5” rim with 275/35/20 Pirelli P-Zero A/S
I wanted to keep a comfortable ride so left the sidewall as close as I could to stock. There’s a slight overall size difference but, I’ll see what it does to the speedo.
Leveling is perfect.
I think I need a front 10mm spacer to equal out vs the rear (see last pic)
Overall, I couldn’t be happier with the look, stance (could be an inch lower but I digress), and investment!
Very beautiful wheels... Looks perfect on that wagon as well. And Yes, I think a 10mm spacer on the fronts will give the stance an even better look... I did same on mine, with stock 19"s and moved the fronts out by 15mm and the rears by 20mm... now both look perfect (pics added as a guide only)
I did the same sort of thing a while back on my E class. The grill, rear diffuser & wheel change totally makes a new car. I added a few pics. Your rides look beautiful.
