Windshield Wipers - Intermittent
only if you cut the engine and immediately open the door, the wipers will also stop
EDIT: in fact my car does exact same thing as OP
You can call MB USA but that will hardly help fix your wipers from "independent dealers".
How MB smart wipers works:
- the wipers module is powered by
- the F-SAM that reads status from
- the rain sensor on windshield
Unfortunately all 3 items: Wipers, SAM, Sensor are able to spoil your ownership.
Luckily MB car systems are computerized. Any factory trained technicians can seriously diagnose your car faults.
90% chance the issue lays with
Either the car is broken or it is a user error if wiper do not stop at the rest position when the car is parked (assuming the door is not opened too soon). Just wondering what the driver could do wrong here.
**************************I STAND CORRECTED****************************************
In fact my car behaves in the exact same way as OP
My apologies!
Your experience is normal function for MB wipers.
Park the car, switch wipers off using the stalk knob, turn the ignition off, then carry on by opening the door and exiting the vehicle or sitting in your car as desired.
EDIT: I have wipers on the first intermittent setting almost always. Makes the wipers stop when entering the garage and wipers start when driving in rain. No need to change the setting in different conditions.
