W213 Service Manuals??
https://www.ebay.com/itm/125532088540
What do you mean with a lot cheaper than ISPPI? The eBay items are illegal copies. Illegal copies should be free (and are).
This does look like a copy of the real workshop manual by content. Even as a pdf print it should work if it has all the documents. It just is clumsy to use as the top level document always has several steps for a bigger repair task and each step is covered by another document (can continue from there). On the right you can see a link to the document that covers one particular step. The question is if you can easily locate that document. Not impossible if each pdf document title contains the numerical document identity as it is on the link.
Someone has had a huge effort when printing all WIS documents. No need for any SW installation is an advantage but makes it difficult to use. Hopefully pdf documents are printed allowing text search.
