E-Class (W213) 2016 - 2023
New (potential) owner looking for feedback on camshaft ASAP (2017 e400 wagon)
Old Sep 19, 2023 | 09:23 PM
Ezpotato's Avatar
2017 e400
I am looking at purchasing a fairly low mileage 2017 e400 wagon. It only has 31k on it and well documented Carfax history from Beverly Hills Mercedes. However, I noticed a couple thousand miles before it was traded in from the 1-owner, it had some camshaft work done.
Vehicle serviced-Camshaft position sensor replacedCamshaft adjuster solenoid replaced
Is this something that can also have other effects? A vehicle inspector I know said that with it being traded right after means that those things that were fixed may have some other hidden things that were not fixed or identified (I think he said maybe oil or something could get into other solenoids or so? Can't remember exactly). Or that there was more things that needed to be fixed which is possibly why it was traded in.
I'm from the Audi world and have been scarred with timing chains, rocker arms, etc. Don't want to buy and inherit problems, esp with such low miles. I tried asking the dealership it used to be serviced at and they were no help.
This dealer doesn't let you take the car to get an inspection, but welcomes mobile inspectors.
The car is mint, so I would love to get it but wanted to get people's opinions.
Carfax shot
Old Sep 21, 2023 | 01:27 AM
Billyismyname's Avatar
W221/W222/W213/X290
The E400 engine doesn't have major problems. If they just replaced the camshaft at that low of a milage that's pretty weird, but it could've been due to the camshaft spinning from where the adjuster sits. It's a problem on most newer mercedes like the M270's & M274's. If the car sounds like it's running fine on idle, there is no rattling on start up (starting it up on a cold engine that's sat 1-2+ hours), then it should be fine. I highly doubt timing will be an issue after driving the car a couple of miles after the replacement of the camshaft.
