E-Class (W213) 2016 - 2023
AC problem
Old Jan 24, 2024 | 04:40 PM
Lau123's Avatar
W213
AC problem
Hello , I have a problem with my E class W213. When I turn the heater , on one side is blowing hot air an on the other side cold air. Went to the dealer to do a diagnose and they said that probably the heater mixing valve is broker but they have to remove full bord of the car to know for sure. I am wondering if any of the owners had the same problem and a solution for this . Thank you
Old Jan 24, 2024 | 05:32 PM
ua549's Avatar
Double check that the temperature setting are both set the same. Otherwise the different settings fight each other.
Old Jan 25, 2024 | 01:06 AM
Diesel Benz's Avatar
There is no mixing valve, no valve separate for the right and the left side. Did they mean a flap misbehaving within the HVAC unit?
Old Jan 25, 2024 | 05:51 AM
Lau123's Avatar
W213
The dealer said air mixture flap servo motor or air mixing valve blocked .
