What is service A3
If the oil pump fails, not changing your spark plugs will not void your warranty.
For a warranty claim to be denied, Mercedes must show that the failure was the direct result of a spark plug failure.
One of the first signs of the need to change spark plugs are;
- Hard starting
- rough idling
- decrease in mpg
Mercedes spark plugs cost double that. One would think that paying double would give you twice the length of service. But no, you only get 1/2 the length of service.
Many years ago, before fuel injection, emission controls and gasoline without present day additives, changing spark plugs every 20/30,000 was necessary.
Pull a spark plug at 50,000 miles from today’s clean burning engines and they will often look like new.
The reason I stick to going to the dealer for now and following their service schedule is because I do not want to have to argue with MB Australia/MB dealer for warranty claims where they may upfront try their best to squirm out of it. That’s the modus operandi here: deny, deflect and then agree under threat of litigation.
I plan to keep my car for 3-4 years beyond warranty. The risk I’m taking in doing so is facing the infamous M260/M264 valve guides’ abnormal wear causing the valves to leak. I’ll actually be quite gleeful if this engine has these issues before warranty expires in late 2025 - then it’s completely on them. The WIS is pretty specific that there needs to be a CEL and a leak test will need to be done before they replace the cylinder head. Unlike MB USA, MB Aust has not yet issued an extended warranty on the M260/M264 cylinder heads.
Going back to op’s topic: MBUsa has specified the spark plug and air filter change at 5 years/50k miles. If the OP isn’t under warranty unlike myself, then he’s perfectly at liberty to delay those items till what he judges is a reasonable mileage/interval
Majority of MB cars are bullet-proof, that is MB's calling card, and the overtly incessant fluid change schedules are just money-grubbing scheme.... I follow my own schedule and ignore the "A or B" service chimes from my car... knock on wood, it has worked charmingly well for my 2013 SLK350
Although I only have 37,000 miles I am eligible to get the 2 maintenance package for $1600 so both would be covered. It sounds reasonable to me although I would be getting the spark plugs earlier than at 50k. How about to you all?
Now I guess the trick is would I find an outside shop that would give me an A service, B service trans change and spark plugs for less than $1600. I am somewhat doubting it, but not sure.
Now I guess the trick is would I find an outside shop that would give me an A service, B service teans change and spark plugs for less than $1600. I am somewhat doubting it, but not sure.
I'm on my second MB and the only time they have seen a dealer is for covered warranty work. Otherwise, I do it myself or take it to an independent shop. MB dealers heavily promote that MB cars are snowflakes that require "special tools" and many people believe this. It is total horse****.
MB cars are mechanical machines with a ICE just like the majority of others. In fact, I find working on my Mercedes' much easier than the many other brands I've owned because of their thoughful components designs and engineering.
Besides removing all the plastic bits, changing spark plugs on our Mercedes is no different than a small block Chevy from the 60's. Anyone that knows how to use common tools can do it.
To each their own. If you find personal value in paying massively inflated prices at a dealer because they may have some magic fairy dust, then by all means do it and be happy!
From my experience maintenance packages, unless they are put into a lease where they can be residualized, do not save you any money.
The package at $1600 only looks attractive based on what the dealer charges, $1200 and $1800 - which to me seems very, very high.
Just my $.02
I did see that it was mentioned on here that someone thought they spent $1000 on the trans change alone so I am doubting that I would save too much. Afterall, I would be paying $1600 for this A, next year's B service and a trans change and new spark plugs all in all. Plus get a loaner both times which is a help.
Now what could change the game is if anyone has paid significantly less for they trans change I guess.
On my mom's S500, she used an indy that a lot of people use around here and later found that he didn't even use the genuine Mercedes parts after claiming to.
