Has anyone fitted one of these? (EV charging port cap)
MERCEDES-BENZ E W213 Rear Hinge Lever Bracket A2137570900 2NEW GENUINE | eBay
hopefully someone can share the wis document
It took about 2.5 hours but would have been faster if there was a detailed video\post out there on how to do it, follow the ones on YouTube for the saloon, lights don't need to come off (mine was just really tough around there and it wasn't 100% obvious there wasn't another clip or fastening) make sure to get all bolts and the plastic pins things underneath and around the wheel wells, and then its just brute force to release the bumper, only tool that most people won't have is a long 10mm socket to get the 2 bolts from inside the boot.
Once the bumper is off, replacing the actual part\cover is easy. There is a pin that, once you take the spring off, just gently knock all the way through with a hammer or other tool.
Then just reverse the process.
