E-Class (W213) 2016 - 2023
Rear Dashcam / Keyless Go Interference
Old Apr 6, 2025 | 10:08 AM
W205C43PFL's Avatar
Originally Posted by Toptick
Really glad this worked for you as well, my Keyless Go has been working since I put the chokes on a week ago. I had one time where the car wouldn't lock or start, but it was right under an intersection of power distribution lines, I wonder if that had anything to do with it.
Old Apr 7, 2025 | 04:35 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Originally Posted by chad500sl
Adding two Ferrite Chokes, one at each end of the back camera seems to have solved my keyless go issues. 3 days without issue after having trouble almost every drive. Kudos to all contributing to this thread!
what diameter did you use ?
Old Apr 7, 2025 | 07:26 AM
Toptick's Avatar
2022 E450 Wagon
The assortment I bought had 5mm, 7mm, 9mm, and 13mm. I used the 5mm as they were the ones that fit, I guess it depends on the size of your wire.
I would send you the ones I have, but postage to Europe would probably cost more than I spent for the ones I bought from our friends at Amazon.
Old Apr 7, 2025 | 07:36 AM
Egonvdv's Avatar
cheers!
i guess the cables should be similar in size, but will also buy an assortment, to make sure i'll get the right fit
Old Apr 7, 2025 | 09:19 AM
chad500sl's Avatar
2017 SL550 (R231), 2021 E350 (W213)
I purchased a set of "3.5mm/ 5mm/ 7mm/ 9mm/ 13mm". The 3.5mm wouldn't quite close on the dashcam wire, so I used the 5mm. They are a little loose and will slide if you push them. It's tight enough they won't slide on their own.
