Problem with boost pressure
I'm new member on forum. I use E220d from 2019 with OM 654.920 engine. Recently I had problem with turbocharger. During accelerate turbocharger was noisy like whistle. During check the turbocharger it had around 1.5mm loose in axial direction. I decided to replace turbocharger. After replacing and adaptation process on new one I noticed an issue. The faults are: Turbocharger 1, boost pressure too high. Turbo boost pressure sensor circuit, signal outside low limit. Discontinuous. Could You give me an advice what is the problem?
Thanks a lot for help
Update:After replace turbocharger I rode 3500km. Boost overpressure still occur (P023485). Turbo now is noisy during accelerate. Sound is like vacum. I did a test with turbo actuator. Engine arround 800 rpm and set actuator to 0% and 100%. When turbo rotates faster, the noise appear. What do You Think? Is the turbo brooken? Maybe regeneration was made incorectly.
