E-Class (W213) 2016 - 2023
Break pedal
Old Jun 14, 2025 | 10:13 AM
Mark Davidson's Avatar
Mercedes E220d w213
Break pedal
Hi
I seem to have a problem with my brake pedal
when i get in car to start the pedal is really hard to push down !
This gets easier as I'm driving .. I also have a sqeak
coming from brakes when I'm braking
Had pads changed last August so still ok
Old Jun 14, 2025 | 10:30 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
When the brakes quit working properly, it turns the brake pedal, into a break pedal.
Old Jun 14, 2025 | 01:46 PM
cscuzzo's Avatar
2020 E350, 2023 E350
My wife's E does the same thing. It took us quite a while to determine the pressure on the pedal made a difference between being able to start or not. She sometimes goes a week without driving it, and I noticed the pedal was very stiff until started. My guess is that it loses some boost pressure after sitting, and the pedal expects more movement to detect that you're depressing it.
I queried the Service Advisor just yesterday. He dismissed my observation, told me the key was probably low on battery. It reminded me why I don't like this particular advisor.
Old Jun 14, 2025 | 02:17 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
What does the battery in the key have to do with the brake pedal pressure?
Old Jun 14, 2025 | 02:25 PM
cscuzzo's Avatar
The Service Advisor completely dismissed the connection to the brake pedal (assuming it was "just a coincidence" despite being the only way to reliably get it to start), but instead repeated the usual reasons for non-starting: either the key has "fallen asleep" and needs to be woken by pressing a button (it apparently does this to save battery when the key isn't in the car), or the battery in the key is low and the car cannot communicate with it to enable the engine start.
Old Jun 14, 2025 | 07:04 PM
W205C43PFL's Avatar
Old Jun 14, 2025 | 07:05 PM
W205C43PFL's Avatar
Originally Posted by Mark Davidson
Hi
Perhaps also check the vacuum check valve, that affects the pressure required to push the brake pedal as well. That said, with vehicle off, the vacuum pump is not running anyways so probably not it.
