E-Class (W213) 2016 - 2023
Air Leveling Function Malfunction
Old Jun 21, 2025 | 09:11 AM
MNIAW's Avatar
2017 M-B E400 4Matic Wagon AMG-Line
Well, it's a day all M-B owners whose cars have air leveling (mine's a 2017 E400 Wagon) dread. This message popped up on my MFD along with the caricature of my car with an upward pointing arrow in it: "Malfunction. See operator's manual" The manual says "The AIR BODY CONTROL function is restricted. The vehicle's handling characteristics may be affected. Drive in a manner appropriate for the current level, but do not exceed 50 mph (80 km/h). Consult a qualified specialist workshop."
Since I've been following this forum for the last 18 months, I didn't panic. I got out and looked at the rear and it had indeed settled significantly. I just let the car sort itself out and once it had, drove it as normal. I had to drive it on a 150-mile round trip that included some highway time so I did exceed 50mph. I noticed what felt like wheels/tires that were out of balance on the rears when I went above 50 (the car was just aligned and had all 4 wheels balanced). The car was manufactured in November 2016 and just passed 71K miles yesterday. I checked this morning and no visible settling and no warning message.
In any case, I'll get it to my independent Mercedes mechanic when I can but I'm down to 1 car at the moment...my daughter had to borrow our other car while she gets hers figured out. Will update as the saga unfolds.
Old Jun 21, 2025 | 11:35 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Almost predictable: 75K miles.
So sorry and hope the repairs aren't too expensive!
Old Jun 22, 2025 | 09:59 AM
MNIAW's Avatar
No drama yesterday...Saturday.
But today (Sunday), the car had settled and will not rise at all. It says don't drive faster than 50mph but it's really undrivable above 5mph. Can't even get a jack under it, at least at the rear jacking point.
Anybody know where the fuse for the compressor might be? 2017 E400 Wagon.
Old Jun 22, 2025 | 02:19 PM
ua549's Avatar
Egonvdv posted complete fuse diagrams for the W213/S213 in 2018.
I posted (p=7475311) a pdf fuse reference as well.
Do a search.
Old Jun 22, 2025 | 06:12 PM
MNIAW's Avatar
Do a search.
Yep, thank you. Found it. Unfortunately, not a fuse.
Old Jun 22, 2025 | 07:52 PM
sidnotgod's Avatar
2017 E43 AMG, 2009 E63 AMG (fuel injector hydrolock, scrapped 2024), 1999 C230 Kompressor (sold)
Any chance it could be the Airmatic valve block?
As I understand it, the computer signals it to open certain valves and direct air from the compressor to the bags at each wheel. Sometimes they get stuck (corroded?) and fail to pump up certain bags or leave them partially open to depressurize.
Perhaps this is your issue? Kind of sounds like it to me, since your issue came suddenly. And the car managed to pump back up and drive fine until it suddenly would not pump at all.
That all sounds like a valve block failure to me and fingers crossed that it is your issue.
I have a 2017 E43 right around your mileage (80k) and will have to make an 1100-mile road trip across the country next month... Airmatic is my biggest concern. I might change my valve block preventatively.
Old Jun 22, 2025 | 11:28 PM
ssquared30's Avatar
W213 E450
Same happened to me. 2022 E450 with about 48k miles at the time. Got the same warning as you, had the car towed to Mercedes. Airmatic pump failed
Old Jun 23, 2025 | 06:40 AM
MNIAW's Avatar
Thanks for this suggestion. I hope it's something as simple as that.
Unfortunately, the car is at our lake house and I don't have any tools, garage, or even a hard stand to work on it myself. There is an excellent Mercedes independent mechanic about 10 miles from us and it will be towed there this morning.
Old Jun 23, 2025 | 07:31 PM
sidnotgod's Avatar
Cool cool! I'm eager to see what it ended up being. But honestly, I think around 75k miles is when one has to start budgeting for the replacement of a front/rear set of bags anyway. I should get on that myself
Old Jun 23, 2025 | 08:38 PM
MNIAW's Avatar
Yeah, my car only has the rear bags...it's Airmatic light. Only for self-leveling of the load on the rear axle (it's a wagon/estate).
When I talked to my local Mercedes independent mechanic today, they said they hadn't seen an Airmatic issue in months but mine was the 5th they've seen in the last 2 weeks.
The towing service screwed me over and had me waiting in the 90+ degree heat for 4 hours before deciding they would come tomorrow morning. It's part of my insurance coverage so I'm stuck using whatever contract they have negotiated. Hope to have the problem diagnosed by end of day tomorrow (Tuesday).
Old Jun 25, 2025 | 08:28 PM
MNIAW's Avatar
Wednesday update: the shop called today and told me the compressor is definitely shot. They will have a new one late tomorrow or early Friday. Once they have the new compressor in, they'll be able to check to see if there's leaks elsewhere.
I asked them to also replace the rear shocks. One of the shock mounts was worn and was making a "thunking" sound when going over bumps (I live on a dirt road...). My previous mechanic who has since retired had done a temporary fix for me but since they're going to be mucking about with the rear end anyway, I asked them to go ahead and replace both. Not going to be a cheap visit but I knew that when I bought the car with 51K miles on it.
Old Jun 26, 2025 | 04:06 AM
sidnotgod's Avatar
Thanks for the update! I would not have guessed compressor, at all. I hope they're not lying...
At the same time, I myself asked so many people (MB parts counter.. etc etc) for a PN# to an Airmatic compressor intake air filter for our 213s like older gen cars have. Nobody found anything. If we really don't have filters for our air suspension, no wonder there are more compressor failures.
Old Jun 26, 2025 | 09:35 AM
MNIAW's Avatar
I’m not surprised. I checked all the fuses for the Airmatic system and they were good. With the car running, I couldn’t hear any air escaping. Sure seems like the compressor is bad to me. This shop is very highly regarded by in-person recommendations and Google reviews.
Old Jun 27, 2025 | 04:12 PM
MNIAW's Avatar
Friday afternoon update...the shop just called. They installed a new compressor yesterday and the system held up over the first 24 hours. He's replacing the spark plugs and rear shocks now and they want to keep it over the weekend to make sure there's no slow leak anywhere else in the Airmatic system.
Interesting take @sidnotgod about the intake air filter for the compressor. You are probably right.
Old Jun 30, 2025 | 08:59 PM
MNIAW's Avatar
Got my car back today. No leaks over the weekend after they put a new compressor in. Not inexpensive but a great mechanic is worth spending money on.
Old Jul 3, 2025 | 05:57 AM
The G Man's Avatar
2019 E300
Thats great news, air suspensions are great when they work. I had 2 cars with air suspensions, both had issues. One had a air spring replaced and the other one had a bad compressor.
Old Jul 6, 2025 | 11:02 AM
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
This. Great when they work but frankly not worth the money. Every car I've had (from Range Rover to Porsche to Mercedes) ends up having a suspension issue due to the compressor or sensor. Coincidentally, my 21 wagon just through up the issue this weekend. Here's hoping it's just the sensor and not the compressor. What a hassle.
Old Jul 7, 2025 | 06:50 AM
The G Man's Avatar
2019 E300
Air suspension should really be a routine maintenance item like a oil filter, change out every 3 or 4 years. In my opinion, the unreliability of the air suspension is not worth that tiny bit of ride comfort and the height adjustment capability. Eveytime I trade in my car with air suspension, the salesman try to go down in trade in price due to the old air suspension.
Old Jul 7, 2025 | 08:19 AM
MNIAW's Avatar
Well, unfortunately, if you want a wagon, you don’t get a choice.
