E-Class (W213) 2016 - 2023
Random brake warning, W213
Old Aug 20, 2025 | 05:33 PM
wje's Avatar
wje
2020 E450
I've been getting the 'check brake pads' msg, brake check light on. Sometimes. It comes and goes. I'm thinking if the wear sensor was actually activated, it would be constant. Connector issue? What else?
Old Aug 21, 2025 | 10:04 AM
figuwx's Avatar
2018 AMG E63s Ed1
connector issue and more than likely, corrosion within the connector. That or a wire has been cut/disconnected via mechanical wear.
Old Aug 25, 2025 | 04:03 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You know the brake pads are not hugging the rotors tightly. There's a gap when pedal is let go.
Old Aug 26, 2025 | 05:45 PM
wje's Avatar
wje
2020 E450
Sensor
The sensor is just a wire that breaks. Once it's cut, it's permanent.
