E-Class (W213) 2016 - 2023
Thumping noise between 60–80 km/h
Old Apr 3, 2026 | 03:29 PM
amaksoud78's Avatar
2022 E200
Hello,
I recently changed my 2022 w213 Tyres to a new Michelln Pilot sport 5, same as original size, front 245/40 ZR R19 and rear 275/35 ZR R19 all are produced during November 2025 (tubeless not RFT) and i did balancing and alignment afterwards.
Since then, I hear a rhythmic thumping noise between 60–80 km/h.
It gets quieter when I brake, and it becomes clearer when I turn the steering wheel to the right side.
I have had the pressure rechecked at multiple shops and TPMS shows it’s ok as well, however not sure what this sound is and whether it was there before changing the tyres or not specially that i don’t hear it unless all windows are closed and no music or any noise around.
Any ideas what to check and how?
Old Apr 3, 2026 | 04:41 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
It's possible you got a badly made tire, you could check and see if one wheel has way more weights than the other three, you could ge them rebalances and check the wheels for runout on the balancing machine
Old Apr 3, 2026 | 05:33 PM
amaksoud78's Avatar
2022 E200
Thank you for the feedback.
i don’t feel any vibrations at all, is is still possible to be a balancing issue?
Old Apr 4, 2026 | 09:17 AM
It's quite possibly a badly made tire that's out of balance, this can be corrected with significant weights, but you can hear it when the heavy spot hits the pavement, or you could have cold patch in the treads?
Old Apr 4, 2026 | 12:06 PM
amaksoud78's Avatar
2022 E200
The tires are brand new and I had visually inspected them prior to installation so cold patches are not an option.
I will recheck balancing and see if any of them has significant weight.
Old Apr 4, 2026 | 02:59 PM
I meant cold Patch as in asphalt pothole patching compound, I ran over some once and had to pick it out with a screwdriver, It thumped on the tire at highway speed
Old Apr 5, 2026 | 02:46 PM
amaksoud78's Avatar
2022 E200
Hello,
I went to the tyre shop today, did rechecked balancing on a road force machine and switched front tyres.
Then I went for a quick ride and unfortunately didn’t notice any improvement
Old Apr 20, 2026 | 12:15 PM
Do you have a fourmatic or 2WD?
Old Apr 20, 2026 | 02:52 PM
amaksoud78's Avatar
2022 E200
Hello, it’s a 2wd
Old Apr 20, 2026 | 07:21 PM
Maybe check the front wheel bearings for adjustment or replacement if the miles are high?
