E-Class (W214) 2024 -
Front License Plate
Old Mar 21, 2025 | 11:27 AM
W205C43PFL's Avatar
Originally Posted by Rick_H
I live in Virginia where it is also required, but they really don't enforce it. I have no plans on putting one on unless it becomes an issue. Before I received the car I was looking around just in case and I came across the "Sly Bracket". I can't recommend this because I didn't buy one so I am just suggesting it for you to look into. I read on some forums with good reviews and it doesn't require any drilling.
They make good stuff from what I read as well but was sly brackets not mentioned prior?
Old Mar 21, 2025 | 12:28 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
It was mentioned in post 12 and said it will not work for the W214.
Old Mar 21, 2025 | 01:31 PM
Huleyman's Avatar
E53 (2025), C300 4MATIC (2014)
Sadly, there is no E-Class newer than 2023 on their fitments list:
https://sly-brackets.com/successful-fitments-list/
Old Mar 21, 2025 | 02:16 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I've found that to be common in a lot of sites that allow you to search by year, make, and model. I guess it's still too new even though it's been out for almost 2 years now.
Old Mar 21, 2025 | 04:05 PM
W205C43PFL's Avatar
Sorry for the confusion my question was meant to reply to the other forum member of which recommended sly brackets and I forgot if sly brackets was already mentioned as incompatible.
Old Mar 21, 2025 | 04:06 PM
W205C43PFL's Avatar
What were some specific limitations that made it incompatible with the W214, curious.
Old Mar 21, 2025 | 04:12 PM
  #32
L1Wolf's Avatar
Veteran: Army
W214 E450
I cannot say, but I'm referring to search forms that many car sites have. You select the make (Mercedes-Benz) then the model (E450), and then year, but there is no 2024 or 2025. Even this board has that issue if you want to specify your car in the control panel. Although that one is missing many years. Many parts on other sites such as Amazon say that a part does not work for my car when I know that it does. Likely due to the seller not adding the new MY for the car. It makes it difficult to find parts unless you know it works.
Old Mar 21, 2025 | 04:39 PM
  #33
W205C43PFL's Avatar
Yes not intuitive at all.
Old Mar 31, 2026 | 09:22 AM
  #34
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
What about a stick-on replica? And you can shrink the size. Have no idea if it passes regulations - but a clever idea.
https://customlicenseplates.us
Old Apr 15, 2026 | 03:49 PM
  #35
herbgo's Avatar
2026 Mercedes Benz GLC 350e, 2026 AMG E53 Wagon
Here's the image that Carbonio shows on their site. I suspect it isn't accurate. It would be helpful if we see a post with an actual installation on an AMG E53.
Old Apr 15, 2026 | 04:02 PM
  #36
E53DadWagon's Avatar
2026 E53 wagon
actual install on my E53 with Carbino
