E-Class (W214) 2024 -
E/W214: Charging E53
Old Jan 9, 2026 | 05:33 PM
  #51
Mercuccio's Avatar
Originally Posted by GregTR
I am almost certain it can work with whole house generators. The issue you're going to run into is that for you to change the monitored circuit for EV management will need to be altered and its limit changed depending on whether you're using grid (you can use panel limit) or generator (you must use generator limit). This requires a config change and that requires a PIN which is meant to be locked out by your electrician. Also, every time you change it, it gets logged and an email generated that you have changed it.
The first issue is that the limit is going to change between the grid and the generator so the monitor needs to be aware of the change in power source.
A separate issue is that I'd rather not charge the EV using the generator unless I give it a one-time permission. I'd rather save the generator fuel for the house. It is also more efficient for the utility to generate electricity. On the PHEV, I can wait to charge the car until the grid is up. I could see a potential with the grid out that I would want to charge the EV using the generator to get some range on the car when the gas pumps are down due to the electrical outage.
I'd like to have a device that senses that the house is powered from the grid and turns off the EV charger circuit unless I override it. It is an edge case, but I would be interested in such a product.
Old Jan 9, 2026 | 06:22 PM
  #52
Mercuccio's Avatar
Originally Posted by bossfost
Picked up my wife's E53 Wagon on 12/31. We've been limited to 110V/Level 1 charging so far. Installing a Level 2 charger in the garage next week; will work better for her usage...several short trips during the day.
The posted PDFs are helpful. Should we have received some sort of PHEV manual with the car? I went through all of the paperwork and there was:
1. Standard E-Class owners manual. I didn't see any PHEV/charging information.
2. Quick Overview Guide
3. Maintenance manual/logbook
4. Very limited manual with the included Webasto charging cable pack (sort of a short pictorial of the two plugs and then legalese).
I think we have everything figured out but I do want to make sure we have a complete set of manuals...for the next guy.
I am new to EV charging too. Here's a quick PHEV charging guide for you. The first question I had is "how do I charge the car?" You can find out how to start the AC charging process here: Starting the AC charging process (level 1/2) | E-Class Wagon July 2025 S214 MBUX | Owner's Manual It is pretty easy once you have done it once or twice. The main steps to start charging are:
  1. Open the outside charging door by pressing on the center, similar to how you open the door for filling a Mercedes with gasoline.
  2. Push a button by the charger port to open the charger socket cover.
  3. Insert the charger connector until in clicks in place. Make sure the cable is not in tension.
If your charger is set to autostart, charging will start immediately. You can also set block out times in the charger app if you want to avoid charging at peak times. You can also set charging schedules in the car. If the charger is not set to autostart, you need to tell the charger to start charging. This is going to be dependent on your charger and the charger settings you have selected.
The second question I had was "how do I stop charging?" You can see the process for stopping charging to the car here: Ending the AC charging process (level 1/2) | E-Class Wagon July 2025 S214 MBUX | Owner's Manual. Here's a summary of how to stop charging.
  1. If the car reaches its target state of charge, it will stop charging.
  2. If you press the "Cancel charging button near the charging socket, it will stop charging
  3. If you use the "stop charging" button in the EV charger app, it will stop charging.
  4. Once charging is stopped, press and hold the button on the charger connector to remove it from the charging socket.
  5. Close the socket cover and flap
The description of the socket indicator lamps is here: Functions of the indicator lamps on the vehicle socket | E-Class Wagon July 2025 S214 MBUX | Owner's Manual
  1. The locking status lamp on the left will be white if the charging cable is locked to the vehicle. The upper curve socket light will light up the socket and match with the locking status lamp.
  2. The charging progress lamp, which is matched by the lower arc over the socket:
    1. will be green if the charging process is complete
    2. flashes green if charging is in process
    3. orange if there is a charging break (charging started but didn't complete but hasn't reached target SoC0
    4. flashes orange if the connection is being established
    5. flashes red if charging is not possible due to malfunction
The third question I had was "What are the charging settings in the car and in the app?" See the settings options here: Configuring the charging settings | E-Class Wagon July 2025 S214 MBUX | Owner's Manual.
Here are some setting options:
  1. You can setup three separate charging programs. You can save your home GPS position and associate it to one of the charging programs.
  2. If you are charging on level three fast charger, you can choose to charge at up to 20 kW (the default) or do a one-time override to charge at 60 kW.
  3. You can set the departure time. This will coordinate with the vehicle's pre-entry clime controls to heat or cool the cabin by the time of departure. The charging time will be optimized for the departure time.
  4. You can enter charging breaks, if for example, you don't want to charge at utility peak times.
  5. You can change the charging power.
  6. You can set the maximum charge level
The charge settings can also be changed in the Mercedes phone app.
At first glance it may appear that there are a number of options. In practice, you plug the charging connector into the socket to charge. Then you end charging (via the car button, app, full charge, etc.) Then you remove the charging cable and holster it in the charger. It is quicker than using a gas pump in everyday usage.
Old Jan 10, 2026 | 12:21 AM
  #53
GregTR's Avatar
2014 E350 Wagon, 2025 GLC 350e, 2026 E53 Wagon
This can be easily managed with Home Assistant using Emporia sensors.
Old Jan 10, 2026 | 10:13 PM
  #54
Mercuccio's Avatar
Thanks for the info. I'll have to check it out.
Old Feb 1, 2026 | 10:34 AM
  #55
herbgo's Avatar
2026 Mercedes Benz GLC 350e, 2026 AMG E53 Wagon
We ordered an AMG E53 wagon and GLC 350e and will be looking to install a Level 2 EV Charger mounted outside (since we park outdoors). The Tesla Universal
Charger gets good reviews - especially for very cold weather conditions we get in southern Ontario. The long 24 ft. cable is thin and not subject to stiffness when cold
and will reach both cars in the driveway.
That said, I'm looking for feedback from anyone who has made the same choice and how the Tesla Universal charger works with the M-B PHEV's. If you made a different
choice - and charge in a cold weather climate - I'm interested in your reasoning.
Thanks,
Herb...
Old Feb 1, 2026 | 01:36 PM
  #56
E53DadWagon's Avatar
2026 E53 wagon
Thanks,
Herb...
I think the Tesla one will be a pain because you will always need to use an adapter. I have a Grizzle one (Canadian made) that works great outside in NY.
Old Feb 1, 2026 | 03:52 PM
  #57
herbgo's Avatar
One of the reasons for considering the Tesla universal charger is that is is compatible for both charging protocols - no adapter needed as it's built into the handle.
Old Feb 1, 2026 | 04:06 PM
  #58
LAZARU5's Avatar
2025 E53 Hybrid
I purchased the Tesla EVSE during the short period that it was offered with a J1772 connector. The newer universal one is definitely the one to get. I have used this version often at hotel destination chargers. Like all of the Tesla EVSEs, it is a very elegant design. You won't be disappointed with it.
Old Feb 1, 2026 | 04:11 PM
  #59
LAZARU5's Avatar
2025 E53 Hybrid
I used a Grizzl-E EVSE for about a year with my Taycan. It got stuck in the Taycan port three times. Although that was probably because of the lame brain computer in the Taycan. The Grizzl-E is known for durability, but the cable is cumbersome and the design is outright ugly compared to the Tesla Universal EVSE.
Old Feb 1, 2026 | 05:25 PM
  #60
2026 E53 wagon
I actually like the design. Looks like a tank. And has performed like on - spends the winters covered in snow with no issues.
Old Feb 1, 2026 | 07:22 PM
  #61
herbgo's Avatar
I'm more concerned with cold weather performance, like during temperatures we're getting now (-15 to -20 degrees Celcius). While the Grizzl-e is Canadian, the cables
are known to go stiff during really cold weather - unlike the thinner Tesla cables. Just wondering if anyone has used the Tesla universal during really cold weather.
Old Feb 2, 2026 | 11:43 AM
  #62
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I have ChargePoint level 2, outside installation, but within a housing like this.
Chicago weather with charging overnight at below zero Fahrenheit temperatures with no effect on charge times, cable flexibility, etc. Compatible with MB and Subaru EV - and future proof as Tesla compatible cable is a $99 swap.
Old Feb 2, 2026 | 04:46 PM
  #63
Mercuccio's Avatar
Take a look at this.
. At Sate of Charge, he puts the cables in a freezer for a day and then tries the cable. Go to 9:00 in the video to see the cable deep freeze review.
If you want really pliable cables in the winter, a rubberized cable that gets high ratings on State of Charge will be the best. However, by the looks of the Tesla cable on the video, it performed very well, due to the thinness of the cable. I would be happy with the Tesla Univeral Wall charger in the winter in my location in in the North East US. In Canada, cold weather cable pliability may be more of a consideration.
I have the Autel MaxiCharger. The reviewer on State of Charge says the Autel is a great charger but the cold weather performance of the cable is really bad. My Autel cable is noticeably stiffer at 9 degrees F, but it doesn't bother me because my cable run to the car is about 4 feet, so I'm not coiling cable on a daily basis. If I was using a longer cable run, a cable that was easier to coil in the winter would be a strong selling point.
Old Feb 7, 2026 | 07:27 PM
  #64
Alan Smithee's Avatar
On the subject of charging, I need to rant. Maybe I am missing something, but this is ridiculous:
  • Why is the default charging program 'standard'? I would think the vast majority of cars are being charged at home the vast majority of the time.
  • Why doesn't the charging program automatically default to 'home' when parked at home? Yes, it briefly offers a screen prompt, but generally I am occupied by other things pulling into the driveway.
  • Why can't the charging pauses be programmed by day? Certainly this metropolis of 17m is not the only place where time-of-use metering is different on weekdays and weekends.
  • Why are the charging pauses not linked to charging programs? Obviously a 'home' program will have different pauses than a 'standard' or 'work' program.
A couple times now the one pause I have programmed has reverted to 12:00am-12:00am which is not helpful.
Old Feb 7, 2026 | 08:22 PM
  #65
LAZARU5's Avatar
2025 E53 Hybrid
It's especially annoying to plug the charger in during a "pause" period only to find it changed to 12:00am-12:00am when you go to start it the next morning.
Old Feb 7, 2026 | 09:32 PM
  #66
Mercuccio's Avatar
I agree 100% on everything above.
I think the charging program is reverting to standard after the charging completes. I was assuming the selected charging program would remain in place until a different charging program was selected.
When I tried to enter charging pauses to exclude peak times, it saved the pause as 12:00am-12:00am which means that it is always paused. I got into the car the next day to find that it hadn't charged at all.
My workarounds are:
1) Change the standard program to be my home program settings. If I want to program an alternate SOC target, I change the home program and select the home program
2) I press the charge options button on the center console before charging for the day to review the charging plan for the night.
2) Use my utility to charge only off-peak so I don't need to program charging pauses. (This option is probably not available to most people.)
Old Feb 7, 2026 | 10:25 PM
  #67
2026 E53 wagon
It it makes you feel any better, the bmw charging app/procedures are just as obtuse.
Old Feb 8, 2026 | 02:15 AM
  #68
Mercuccio's Avatar
My workarounds are:
The standard program likes to reset to a target charge of 100%. My first workaround doesn't work. Selecting the program and picking the target SoC before each charge seems to work.
Old Feb 8, 2026 | 02:38 AM
  #69
Mercuccio's Avatar
What makes me feel better is that Mercedes did a great job on the hybrid drivetrain. Mercedes may have not figured out all the Hybrid/EV software yet, but they've done a good job making a nice driving PHEV. The hybrid interface to the driver is well thought out. I like how the electric power display goes down when charging on overrun and the power display goes up when consuming power. 12 O'Clock is the peak of electric usage. As power needs go past the 12 O'Clock, the combustion engine turns on. The RPM display starting at 0 in the 12 O'Clock position works well. The haptic stop on the accelerator pedal is easy to feel when pulling out and wanting to leave the combustion engine off.
Mercedes may have botched the turn signal indicators by hiding them behind the steering wheel, but the interface to what's happening with the electric motor, traction battery and combustion engine is a great design.
Since the driving experience is so good, I can forgive the issues that @Alan Smithee mentioned. I'm betting that Mercedes will fix those issues in future software releases because they are obvious to anyone who charges the car.
Old Feb 8, 2026 | 02:55 AM
  #70
Mercuccio's Avatar
It seems like the power display from regen to electric motor to combustion engine RPM was designed by a race car driver with Ph.D's in mechanical engineering and human factors.
Then his drunk cousin who plays Angry Birds 6 hours a day at work placed the turn signal indicators on the display and wrote the charging program program.
Old Feb 8, 2026 | 08:48 AM
  #71
LAZARU5's Avatar
2025 E53 Hybrid
You forgot to mention that the drunk cousin has never driven a car let alone an MB.
