E-Class (W214) 2024 -
Super screen help
Old Jan 17, 2025 | 07:18 PM
JustBlessed's Avatar
2025 e450
Super screen help
I just wanted to know if the passenger screen can control the radio ( changing stations etc. )? I’m assuming it should but it doesn’t. It would make most sense for the passenger to be able to change the stations. When it starts up it asks to pick a profile but it doesn’t allow you to choose the drivers profile. It says “profile already in use”. Any suggestions? Thanks.
Old Jan 18, 2025 | 12:41 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
They can choose guest or make their own profile. I've not had anyone do anything other than guest. And yes, they can change the audio to the car speakers. Normally it's setup to use a Bluetooth headset for the passenger but there is an icon in the bottom left of the screen to change from headset to car speakers. Then whatever they choose on the passenger screen is played in the car. It works like a different audio source though. The center screen audio does not change. It only pauses however I was not on radio when I tried this. I was playing music on a USB stick and my passenger changed it to play music from their phone. The center screen still showed my USB music but on pause. It's like an independent audio system with an option to play through the car speakers or Bluetooth headset.
Old Jan 18, 2025 | 01:14 PM
2025 e450
thanks for the info. I’ll try that headset to speaker button but if I remember correctly it didn’t work with Satellite radio. Now that I think of it it’s probably because their profile isn’t subscribed to Sirius.
