E/W214: First "Official" Service Questions
$320 for an oil change, no matter how you cut it, is crazy: Oil at $6 a quart is at most $50 and the filter at most is $25: The balance of $245 is the pick up and loaner. As I posted my dealer does the "A" service as an express service, under one hour, about $200 while you wait. My Indy shop for $160 - also under an
hour.
If you know anything about horses then you know that a horse needs both oats and hay: that is why they are put out to pasture to graze.
For $320, did the dealer at least wash and detail your car?
No. Mobil 1
see: https://www.costco.com/s?dept=All&keyword=Mobil+1+oil
and
see: https://www.walmart.com/search?q=Mobil+1
Thoughts on that, please?
Thanks.
Thanks.
Almost all cars today use some sort of Turbo boost - including domestic and Asian. To the best of my knowledge, none of these cars recommend an early oil change.
Having said that, there is nothing wrong with accelerating the oil change intervals. The only downside is the extra expense. Personally I follow the manufacturer's suggestion and waited until 10K for the first oil change.
Hope this helps
Thanks.
Of course there is no way to prove or disprove your theory other than changing the oil every 10K miles instead of 5K and waiting 15/20 years until you have 150K miles on your engine. (I average 8K miles per year so to get to 150K miles will take almost 20 years)
Years ago, without synthetic oil, we changed our oil every 2,000/2,500. Engine tolerances were not great, economy was 13/15 mpg on the open road, engines were not efficient and the oil at 2,000 miles was black. Engines tolerances were so bad, between oil changes it was common to add a quart! Those days are long gone and modern engines require far less maintenance than engines of even 15/20 years ago. Engines run far cleaner and oil last a lot longer and needs to be changed far less frequently.
At the 10K intervals, I go with the A-Service or the B-service, whatever is called for, with the Engine air-filter and the Cabin-air filter added in, even if the Service does not call for it.
Some folks may consider that a waste of money, and I certainly accept that may be the case.
PS: I over-maintain my cars and thus this is just my personal preference to do it this way. My prior ML320 (purchased new) was functioning like a Swiss watch, at 240K miles, when I donated it, with no problems whatsoever, other than changing wear-and-tear items during the period of ownership……and of course the shortened interval maintenance.
During the air intake process, if the filter is clogged, the efficiency of power generation goes down, and the engine is literally choking (a bit of an exaggeration, of course).
Even if the filter appears clean, the pores are all clogged with microscopic dirt particles, not readily visible to the human eye, but is still reducing the efficiency of the engine and consequently, compromising the power generation.
Similarly, if you wait till the engine air filter is visibly dirty, then the engine probably had been struggling along for months.
So I use changing the Engine Air Filter as a cheap way to help the engine breathe better. Happy engine, happy owner !
