E-Class (W214) 2024 -
How stiff is the new E53 really?
Old May 26, 2025 | 04:09 PM
53RO D4Y's Avatar
'25 E53, GLE 450, C300, GLC300
I have not adjusted the tire pressure from when I got it from the dealer.
The issue isn't the grip; it's more the noise than anything else. I'm in NY and the roads are patched up and relatively uneven, esp. the side streets around where I am, that's where the noise and ride quality are a slight factor - again, nothing that would change my mind about the car. Despite the relative increase in noise, I'm very happy with the ride.
Old May 26, 2025 | 04:41 PM
W205C43PFL's Avatar
Tire pressure affects the noise and vibrations too. Drop the pressures (measured when cold, like first thing in the morning) and set it to the pressures of the desired load on the gas cap but honestly, if you are happy with the ride as is, might not be worth it.
Old May 26, 2025 | 04:42 PM
W205C43PFL's Avatar
As you know already, dealerships overinflate tires when they sit in the lot or during transportation in an attempt to minimize flat-spotting.
