Front license plate mounting options (E53)
Even though the linked case is mostly sales tax evasion, Tennessee isn't the only state cracking down on out-of-state purchases and registrations.. Proceed with caution!
As you can see, I don't have a front plate. I do live in a state that requires both, but selectively enforces the rule. If ticketed for a missing plate it's a "fix it" ticket, meaning you have X days (usually 30) to correct. If you "fix it" there is no monetary fine. Almost seems as though the more expensive your car, the less likely you are to have a front plate. If I ever have to install it I would probably go Carbonio.
Carbonio mounts with super strength adhesive. Very difficult to center perfectly.
platypus is easier to install and, to my eye, looks better. However, time will tell if the single bolt mounting is strong enough for daily use.
The offset of the standard dealer installation (driver's side) and the Platypus (right side) doesn't quite look right to me. I prefer the center mount approach the Europeans use and am hoping our taller Ontario plates don't obstruct the
center grill too much.
BTW, for those considering the Carbonio, the order and delivery experience was outstanding. I ordered the kit on Saturday and received the package on Tuesday via UPS. As fast as Amazon.ca!
Carbonio does not have an option to change vertical adjustment, only horizontal to my knowledge as it mounts lower and clips in, holding itself from under the bumper above the lower lip between the air dam.
Sto and Show reduces ground clearance in front by 0.5”. Platypus does not interfere with radar at all.
drill location is far more hideous for E53 (vs 450) - it goes up high next to headlight. Sigh.
I like the centered look much more than the side.
no interference at all with any Driving assist functions and engine temps are ok.
Would suggest, just installation takes time and make sure to check it’s tightened occasionally
