E-Class (W214) 2024 -
Front license plate mounting options (E53)
Old Apr 16, 2026 | 12:58 PM
  #51
W222S's Avatar
X253 GLC3004M, 222 S400, Ferrari Roma, Tesla Model S
no problem with wet heavy snow, ski resorts etc. Works very well and nice and centered
Old Apr 16, 2026 | 02:50 PM
  #52
herbgo's Avatar
2026 Mercedes Benz GLC 350e, 2026 AMG E53 Wagon
Beautiful!! Love that you are driving it in the snow!! That is my plan as well!
Old Apr 25, 2026 | 12:04 PM
  #53
E53DadWagon's Avatar
2026 E53 wagon
I have a sickness. My notes:
OEM
Pros: factory item
Cons: have to drill / make hole prominent place on painted part of bumper
STO-N-SHO
Pros: secure fit, does not interrupt light ring around grill, very easy to remove
Cons: decreased ground clearance (minor), maintenance required (occasionally supposed to oil the pin used to remove it). At first I thought airflow might be a con, but after seeing it installed, I am not concerned.
PLATYPUS
Pros: boy-racer looks, very high quality item
Cons: interrupts light ring around grill, boy-racer looks, held in place with one bolt and if it loosens, plate would swing down and scratch bumper)
CARBONIO
Pros: adhesive mount
Cons: interrupts light ring around grill, very difficult to mount perfectly centered (adhesive super strong so make sure you get it right the first try)
Old Apr 25, 2026 | 01:01 PM
  #54
e53driver's Avatar
I prefer a symmetrical center mounted location.
There may still be two other options for this location, one being the non-AMG e class mount (unconfirmed if it will fit but it would still block grill light) and a "flipped" Carbonio mount as described by their customer service rep "the plate holding section can be rotated 180 degrees so that the plate is hanging downwards infront of the grille - though this position hasn't been tested and may not be ideal" which may not block the grill light but would block more of the lower air intake.
Anyone with a Carbonio able to test this?
Old Apr 25, 2026 | 03:07 PM
  #55
McNeo's Avatar
W214 E350
If you mount Carbonio correctly and adjust it according with the tools they provided, then it should not block your grille light. This is something I was discussing with the manufacturer prior to ordering, as that would have been a look-killer for me.
Old Apr 25, 2026 | 04:31 PM
  #56
Cao Black's Avatar
2015 ML350+2025 E350
In your excellent example, can the front plate be mounted without a frame?
Old Apr 25, 2026 | 04:53 PM
  #57
McNeo's Avatar
W214 E350
Yes, you can mount without a frame. I just use the 4B-Duo since I sometimes street park.
https://4bumpers.com/duo.html
Old Apr 25, 2026 | 07:40 PM
  #58
e53driver's Avatar
Looks like the best solution! Do you have a daytime pic?
