Chipped Center Console - What Should I Do?
Well, a protective film also could do the trick you know some guys have their cars ppf wrapped .
However, I COULD NOT get the cover to slide open. The slight flange on the trim piece, which helps it fit securely in the opening, prevents the sliding cover from dropping down and moving.
Your results might vary, but I will not be using it, even though I didn't think it looked too bad.
Different view. Do you really think it looks that bad? Moot since it prevents console from opening, but still...
