FS: W203 C32 AMG airbox with Green Filter (red). For M112 V6 motor.
MBworld Guru
white and whiter
Fits M112 V6. a nice add-on for C240/320. gives much better breathing ability for the M112. search in MJ50's big thread for C32 airbox on one of the last couple pages.
C32 airbox setup with green filter (T-splitter, right airbox, left airbox, right intake tube, left intake tube, heat cloth wrapped on the intake tube, airbox resonator is already gutted out, Green Filters, front cover) $350 obo plus shipping.
SL55 y-splitter setup used for C32 $70 shipped. there's a little hole on the driver side from rubbing against the clip on the fire wall. can be easily patched.
EDIT: pictures added.
2003 C-Class Sportcoupe
I'll have pictures of them tomorrow.
Check your PM box.
Peter Shek
MBworld Guru
white and whiter
what year? you should have room for the airbox, but you'll need to re-route the intake tube if you have the W210. if you have the W211, you will need the spacer thingy i described, but I don't know if the length of the intake tube on the 32 airbox will be long enough for you. you might have to custom some tubing up front.
This is best for W203 and W209.
E320
Thanks!
C55 ///AMG, 535xi
bump for frank!
there ARE noticeable gains in power and sound for a M112 NA motor! I know! I've done it before!
and frank...i'll LINK this to crossfire forums for u, the guys there would want this!
