VOLTPHREAKS 6.5 lb battery
This will sve you 50 lbs over stock and it can be used daily. The battery will save your fuel and make you spry. Tremendous set up and simply fits in where stock battery mounts.
1 battery and two terminals and cables included
first 350.00 takes it
Paypal
jmkdog@covad.net
Paypal
jmkdog@covad.net
![](http://i57.photobucket.com/albums/g239/jmkdog/SN850340_edited.jpg)
I used it for months no problem but it has little reserve. If the car is off and you sit and listen to the radio for 20 minutes itwill DIE! It keeps the same Volt readings as the stock battery while engine is on. 40 minute reserve is minimal compared to several hours on the stock battery. As long as you drive your car this battery is tremendous
BUMP!! Comon guys this is 50%off a battery that is a few months old.
300. plus shipping ,its only SIX POUNDS
It will fit any car it is 1/4 the size of your stock battery.
I had to go back to stock to meet the conditions of my companies lease terms. My car is almost 100%stock now cept for the painted side markers and some filters
