80mm Throttle Body Y-pipe and some other bits
S/C inlet gasket - 113 141 07 80 $6.00
80mm TB gasket - 137 141 07 80 $5.00
80mm Y-Pipe with tubes - 113 090 03 29 $165
Ordered by mistake and can't use them. OEM new in box.
These are the 80mm intake y pipes for an 80mm throttle body upgrade vs. the stock 74mm throttle body on an E55, CL55, SL55, or CLS55. They connect the stock airbox to the new bigger 80mm throttle body (vs. the 74mm intake y pipes). These are stock on the 2007 SL55 which is the only year that has the 80mm throttle body from the factory.
05 E55
05 E55
Guys, I can get more of them, and the actual throttlebody as well. Anyone who needs them just PM me. And if you need the body itself, let me have the part number and I'll find out what I can get it for.
I get a discount on any OEM part in return for never hassling them with returns, which is why I 'own' this set.
