*feeler* 55K 195mm crank pulley set
I'm considering going a different route with my car and like to see if there is anyone interested in this pulley? I makes crazy torque, last dyno I was on was a Mustang and it made 680 and 550 hp, Iat are kept in check with water meth injection and seem to peak at 80ish or so. Its and aluminum ring on a stock center section and has maybe 4k miles on it.
thinking 750.00 with water pump pulley and a used belt. all you would need is a crank bolt.
pulley is still on my car and I have not made up my mind yet.
Ok....1000 views and not one comment! lol thought this would catch the eye of the hard core but maybe its just too hard core...
anyways
the best 1/4 mile time on this set up was 11.28 @ 128 with a rough tune. I'm sure there's more in it.
anyways
boo....now you tell me!Just put on the 185. Would have taken this from you. I just got my cooling mist meth injection kit too! Good luck with Sale....Somebody jump on this..
BTW, what are you doing with the car?
Jeremy with OE tuning, first flash made 100 ft pounds of TQ but HP looked fantastic to about 4800 then kinda made a dip, we did some checking and could see that the fuel pressure was dropping right were there dip was. My car had over 100k miles on it and we figured that was a major contributing factor. Instead of doing the fuel pump and filter with OEM parts i redid the whole set up(I have a thread on the subject) with a very much over kill pumps,line,filters,regulator.
