Stef's aluminum fabbed oil catch can
Old May 28, 2011 | 08:32 AM
NitrogenBalance's Avatar
none
Ran as a open system at the end of a crankcase pump evac system venting to atmoshere. Threaded drain plug at bottom, 10AN side fitting, 10AN top fitting. The filter can be removed and a fitting can be used to set it up as a closed system as many here use. Much nicer than the ebay one's.
$60.00 shipped. Most likely throwing in the anodized 10AN-5/8 push lock fitting in picture and the top fitting if I can find it, another 10AN-5/8 but 90 degree.
Old May 29, 2011 | 08:01 AM
none
Including a few sections of 3/8(8an) and 5/8(10an) stainless braided hoses used to replace the three OEM hoses from the valve covers.
Old May 30, 2011 | 03:23 PM
x_X_RACER_X_x's Avatar
2005 C55
Can PM - please PM me
Hi - was trying to PM but for some reason cannot PM you regarding catch can. Please get back to me on this.....
Matt
Old May 30, 2011 | 09:16 PM
none
Sent you a PM, not sure why it would't work. Maybe you need a certain amount of posts or something. Let me know if you don't get it.
Old Jun 3, 2011 | 01:31 PM
none
Collecting dust and not oil.
Still needs a home.
