Cls55 AMG Block for sale
Old Feb 13, 2012 | 04:26 PM
threestarchrome's Avatar
2004 E55 AMG/2007 Cls 550
i have a cls 55 engine block for sale car sucked up water hydro locked and bent some valves on driver side head make offer still have oil pump etc car had 65k miles located in tampa fl crank and pistons still turn complete circle text me 678-770-4730 also have throttle body and altenator minor lil salvageable stuff
Old Feb 13, 2012 | 04:32 PM
KLR CLS's Avatar
CLS63 PP
How bad are the heads? Would they be salvageable to a porting core?
Old Feb 13, 2012 | 04:36 PM
i would say yes due to when i turn motor with valve covers off all the rockers move up and down freely except cyl 8 u can see looking down the intake holes the valve is bent and is beeing prevented from moving pm me if u need any other info i have hard time finding back my threads once i leave e, thanks
Old Feb 13, 2012 | 06:48 PM
Fabio D's Avatar
210 55
How about the connecting rods? you check all 8 for bent ones?
Fabio Daniel
Old Feb 13, 2012 | 09:12 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If it hydro locked, then the whole motor should be trash. If water compressed and bent a valve, then rod may be bent too. Valve should have been closed on the compression stroke, if water went in, so have you done a compression test?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 14, 2012 | 09:29 AM
AMG Chris's Avatar
2007 CLS63
What are you expecting to get for it?
Old Feb 22, 2012 | 02:18 PM
AMG Chris's Avatar
2007 CLS63
Seller wants $1,500 for what you see in the pictures.
Old Feb 22, 2012 | 08:12 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
For $4k you can actually find a working engine with SC !
