For Sale: 82mm Mercedes Throttle body
Old Jul 23, 2014 | 03:41 PM
Lelix's Avatar
2003 E55
Looking to get rid of some spare parts since I no longer have the vehicle.
Genuine M273, 82mm Mercedes throttle body. Used, but fully operational.
Part number A 273 141 03 25
$350 SHIPPPED
Located in Toronto Canada.
Old Jul 24, 2014 | 09:29 PM
Daarthvader's Avatar
E55 AMG
$350 SHIPPPED
Pm'd you!
Old Jul 26, 2014 | 09:46 PM
Lelix's Avatar
2003 E55
BUMP
It seems a lot of people are mislead about the 82mm TB's and their fitment on the M113K motors.
ELECTRICALLY this is a plug and play unit that requires no pin swapping or modification to the wiring. However, no 82mm TB will bolt up to the M113K out of the box. The options are the following.
1.Use an adapter(bolt on or weld on) on the existing factory 74mm snout which then has to be ported to 82mm. In other words the supercharger has to come off.
2. Use an 80mm Supercharger snout, bore it to 2mm over, weld on extra material on the snout and relocate 2 mounting holes resulting in a factory-like flush mount of the TB
In addition to the above work a larger y-pipe elbow will also be needed.
With that being said, this listing is for THROTTLE BODY ONLY
