Mark this thread as Sold
!NEW! - ASP 172mm Crank Pulley Kit
Old Mar 5, 2015 | 04:13 PM
GregMB's Avatar
Brand New, Never Installed.....
ASP 172mm Kit. Built from a 100% OEM MBZ Crank Pulley for correct dampening, with 6 dowel pins to permanently lock the larger aluminum pulley ring in place!
This is the absolute BEST way to build a larger crank pulley, and retain perfect OEM reliability.
172mm is the perfect compromise between HP/TQ and heat management for the M113K motors.
Includes everything you see in this photo (including new MBZ "stretch to yield" crank bolt)
For an extra $50, I will include a beefier ARP crank bolt (not a single use bolt like factory)... which can be torqued to a much higher rating (250Lb/Ft). Simplifies installation and increases clamping power substantially....
$750 + the ride (includes the extra ARP crank bolt. You'll get both...)
$700 + the ride (includes the standard OEM crank bolt only)
-G
Old Mar 10, 2015 | 04:20 AM
V TO E55's Avatar
05 E55/08 C6 Z06
If your willing to take $500 shipped to 91405 CA with out the bolt let me know
Old Mar 16, 2015 | 02:37 PM
GregMB's Avatar
TTT
Old Apr 1, 2015 | 04:08 PM
GregMB's Avatar
!!!! SOLD !!!!
