Engine partout - 2003 S55/E55 M113K (5.4L supercharged) - heads, crank, pistons, more
Old Apr 13, 2015 | 08:11 PM
whit32's Avatar
2003 S55 AMG
NOTE: ALL parts have been sold EXCEPT the pistons. These are still available:
Pistons and connecting rods (complete)
2003-2008 Mercedes CL55 CLS55 E55 G55 S55 SL55 5.4L AMG
Seven available
Piston 1130301517 (113 030 15 17)
Alternate 1130304317 (113 030 43 17)
Connecting rod 1130300420 (113 030 04 20)
https://lh4.googleusercontent.com/-y...405_163506.jpg
https://lh3.googleusercontent.com/-V...405_163512.jpg
https://lh5.googleusercontent.com/-C...405_163515.jpg
https://lh3.googleusercontent.com/-v...405_163527.jpg
https://lh6.googleusercontent.com/-W...405_163536.jpg
https://lh6.googleusercontent.com/-y...405_163606.jpg
https://lh6.googleusercontent.com/-1...405_163609.jpg
https://lh4.googleusercontent.com/-d...405_163615.jpg
See diagram and compatibility:
http://www.fetchparts.com/p/Mercedes...130301517.html
http://www.fetchparts.com/p/Mercedes...130300420.html
Mercedes-Benz CL55 AMG 5.5L V8 2003, 2004, 2005, 2006
Mercedes-Benz CLS55 AMG 5.5L V8 2006
Mercedes-Benz E55 AMG 5.5L V8 2003, 2004, 2005, 2006
Mercedes-Benz G55 AMG 5.5L V8 2005, 2006, 2007, 2008
Mercedes-Benz S55 AMG 5.5L V8 2003, 2004, 2005, 2006
Mercedes-Benz SL55 AMG 5.5L V8 2003, 2004, 2005, 2006, 2007, 2008
======================SE============
THE FOLLOWING PARTS ARE ALL SOLD. THANKS!
Parting out the engine from my 2003 S55 AMG. All parts from the longblock are available (no accessories) except the block and one piston which are bad due to wear from excessive piston slap. Engine was running fine prior to disassembly except for the piston slap noise. I have disassembled and inspected everything, and it all looks great. No abnormal wear, no pitting or rust, no damage. See pictures and full details below, more pictures at https://plus.google.com/photos/10758...PS3nM_xgtvl2QE
All the main engine parts are from a 2003 S55 with 92k miles. The oil pans and pump are from the replacement engine I purchased, which came from a 2004 E55 with 49k miles. In general, the engine parts will fit any M113K (2003-2008) including C55, CLK55, CLS55, E55, SL55, S55 (some specifics are listed below) -- but be sure to check fitment.
Everything is available for pickup in Cary, NC. I will ship at actual shipping cost as quickly as possible. Prices are firm at the moment (everything is priced well below recent ebay sales) but I will consider discounting multiple items purchased together. Email or call for more details. whit32@gmail.com, 919-454-5445
Fits 2003-2008 Mercedes CL55 CLS55 E55 G55 S55 SL55 5.4L AMG
Right cylinder head + valve cover $400
Head assembly 1130105620, Camshaft 1130508801, Valve cover 1130100430
Left cylinder head assembly + valve cover $400
Head assembly 1130105720, Camshaft 1130508701, Valve cover 1130100730
Pistons and connecting rods (complete) $175 each
Seven available. Piston 1130301517, Connecting rod 1130300420
Crankshaft $400
Mercedes part number 1130300301
Timing cover and oil filter housing $175
Timing cover 1120100833
Fits 2003-2008 Mercedes E55 SL55 CLK55 C55 5.4L AMG
Upper Oil Pan $200
Mercedes part number 1130141302
Lower Oil Pan including level sensor $200
Pan 0041536628, Level sensor 0041536628
Oil pump, Oil pump chain, Oil pickup, and Windage tray $250
Pump 1371810201, Pickup 1131860715, Tray 1130140566
___________________________________________
Right cylinder head (complete) + valve cover
Head assembly 1130105620 (113 010 56 20)
Stamped 1130162401 (113 016 24 01)
Camshaft 1130508801 (113 050 88 01)
Valve cover 1130100430 (113 010 04 30)
https://lh6.googleusercontent.com/-1...405_161518.jpg
https://lh4.googleusercontent.com/-2...405_161537.jpg
https://lh4.googleusercontent.com/-G...405_161556.jpg
https://lh6.googleusercontent.com/-b...405_161529.jpg
https://lh6.googleusercontent.com/-r...405_161524.jpg
http://www.fetchparts.com/p/Mercedes...130105620.html
Mercedes-Benz S55 AMG 5.5L V8 2004, 2005, 2006
Mercedes-Benz SL55 AMG 5.5L V8 2004, 2005, 2006, 2007, 2008
Left cylinder head assembly (complete) + valve cover
Head assembly 1130105720 (113 010 57 20)
Stamped 1130162501 (113 016 25 01)
Camshaft 1130508701 (113 050 87 01)
Valve cover 1130100730 (113 010 07 30)
https://lh6.googleusercontent.com/-o...405_162541.jpg
https://lh6.googleusercontent.com/-x...405_162552.jpg
https://lh6.googleusercontent.com/-X...405_162606.jpg
https://lh6.googleusercontent.com/-r...405_162546.jpg
http://www.fetchparts.com/p/Mercedes...130105720.html
Crankshaft
Mercedes Part Number 1130300301
In good shape. Normal wear for the mileage. Bluing of the crank seen in the pictures is from the factory heat treatment (they all look like that!). NOTE: Some time in 2003-2005 Mercedes changed the output flange bolt pattern on the crankshaft slightly. This crankshaft has the EARLY pattern, which has eight evenly spaced bolts. The later crank has the bolts “paired” with larger spacing between the pairs. According to the ETK, this crank will fit cars prior to engine code 60 046179. It WILL fit later cars, but will require a different flex plate for the transmission.
https://lh4.googleusercontent.com/-U...405_164612.jpg
https://lh6.googleusercontent.com/-M...405_164634.jpg
https://lh6.googleusercontent.com/-l...405_164618.jpg
https://lh6.googleusercontent.com/-W...405_164642.jpg
https://lh4.googleusercontent.com/-D...405_164646.jpg
https://lh6.googleusercontent.com/-c...405_164652.jpg
https://lh6.googleusercontent.com/-F...405_164718.jpg
https://lh6.googleusercontent.com/-F...405_164724.jpg
https://lh4.googleusercontent.com/-n...405_164739.jpg
2003-2008 Mercedes C32 C55 CL55 CLS55 E55 G55 S55 SL55 SLK32 SLK55 3.2L 5.4L AMG
https://lh4.googleusercontent.com/-E...413_002812.jpg
https://lh4.googleusercontent.com/-e...413_002753.jpg
http://www.fetchparts.com/p/Mercedes...120100833.html
Mercedes-Benz C32 AMG 3.2L V6 2002, 2003, 2004
Mercedes-Benz C55 AMG 5.5L V8 2005, 2006
Mercedes-Benz CLK55 AMG 5.5L V8 2005, 2006
Mercedes-Benz E55 AMG 5.5L V8 2004, 2005, 2006
Mercedes-Benz G55 AMG 5.5L V8 2007, 2008, 2009, 2010, 2011
Mercedes-Benz SLK32 AMG 3.2L V6 2002, 2003, 2004
Mercedes-Benz SLK55 AMG 5.5L V8 2005, 2006, 2007, 2008, 2009, 2010
Upper Oil Pan
2003-2008 Mercedes E55 SL55 CLK55 C55 AMG 5.4L
Mercedes Part Number 1130141302 (113 014 13 02)
Alternate Part Number 1130141802, 1130141102, (113 014 18 02, 113 014 11 02)
Stamped 1130141302 (113 014 13 02)
https://lh4.googleusercontent.com/-v...405_234220.jpg
https://lh4.googleusercontent.com/-s...405_234203.jpg
https://lh6.googleusercontent.com/-o...405_234232.jpg
http://www.fetchparts.com/p/Mercedes...130101028.html
Mercedes-Benz CLK55 AMG 5.5L V8 2003, 2004, 2005, 2006
Lower Oil Pan
2003-2008 Mercedes E55 SL55 CLK55 AMG 5.4L
Mercedes Part Number 1130101028 (113 010 10 28)
Alternate Part Number 1130100828 (113 010 08 28)
Stamped 1130141103 (113 014 11 03)
https://lh4.googleusercontent.com/-W...405_234259.jpg
https://lh6.googleusercontent.com/-n...405_234304.jpg
https://lh6.googleusercontent.com/-M...405_234328.jpg
2003-2008 Mercedes E55 SL55 AMG 5.4L
Pump 1131802301 (113 180 23 01)
Pickup 1131860715 (113 186 07 15)
Tray 1130140566 (113 014 05 66)
https://lh6.googleusercontent.com/--...406_171117.jpg
https://lh6.googleusercontent.com/-f...406_171121.jpg
https://lh4.googleusercontent.com/-c...406_171129.jpg
http://www.fetchparts.com/p/Mercedes...131802301.html
http://www.fetchparts.com/p/Mercedes...131860715.html
Old Apr 29, 2015 | 08:38 PM
whit32's Avatar
2003 S55 AMG
Old Nov 7, 2016 | 10:09 AM
whit32's Avatar
2003 S55 AMG
EVERYTHING HAS BEEN SOLD.
Old Nov 10, 2016 | 12:57 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Howst? Just out of curiousity what were you looking for at the crankshaft?
Old Nov 10, 2016 | 12:59 AM
Khan 55's Avatar
2004 CLK55 AMG W209
My bad read above $400.
