FS: VR Tuned ECU Tuning Box Kit Mercedes CLA 250 CGI 42HP Gain Model: VRT-121174
New from VR Tuned is this performance Tuning Box kit for the Mercedes GLA 250 2.0L Turbo engine. This tuning box kit is a plug and play solution to tune your cars fuel, timing, and boost giving you up to 40% more power and 20% fuel savings. The VR Tuned ECU Tuning Box Kit gives your GLA 250 a gain in power from 211bhp to 253bhp gaining you 42hp!
Plug and Play for easy removal to avoid warranty issues
Designed for turbocharged vehicles only
Does not lock to vehicle or VIN
Harness has OEM style connectors, no splicing or cutting
Tuning Box features an aluminum weatherproof case
Digital Microprocessor Controlled
Installs in 5 - 45 minutes depending on vehicle
Proven power gains
3 year warranty on parts
Tuning Box cannot eliminate CELs from catless or high flow cat exhaust parts
On the back of the box is a removable cover with dial settings you can adjust. This is to allow small adjustments to the power setting so the box can work correctly in different climate conditions and on different quality fuel.
https://www.vividracing.com/catalog/...150784831.html
