Battery recall for '22-'23 - Class action?
Old Aug 9, 2025 | 01:15 PM
GhengisAhn's Avatar
2023 EQB 350
I did the software update and I’m actually getting some weird notices. Sometimes it says my airbag has deployed and for me to pull over safely. Other times it gives phantom crash warnings.
I took it in to service to look it up. The tech said that there is zero recorded alert messages, which normally would be recorded.
he also mentioned that it’s been a complaint of this battery software update. So more to follow I suppose… or not. I don’t know what Mercedes is going to do.
Old Aug 9, 2025 | 01:43 PM
abhansali's Avatar
The other day, my daughter who drives this car, said she also was hearing some weird noise. But then next time she drove it went away. Now after hearing this, maybe it was related. She said it was kind of like brake grinding noise?? Is that what it sounded like for you?
Old Aug 9, 2025 | 01:59 PM
GhengisAhn's Avatar
2023 EQB 350
Not sure if that was directed to me, but no brake grinding noise for me. For the most part I haven’t had any issues with the software update other than what I mentioned. It’s just faulty sensors going off randomly but it’s not frequent or often, it just happened to go off a couple times after software update.
no problems charging at fast chargers either, but not to insult anyone’s intelligence, even if a charger is rated for 130kwh, it may only push out 90 and that’s due to a multitude of factors. Chargepoint especially if it’s next to another station will share or distribute power.
electrify America and evgo is generally good about their stated outputs at their larger stations even if it’s somewhat busy, but a couple do distributed load even if it’s not busy.
Old Aug 9, 2025 | 08:25 PM
nsoltz's Avatar
2023 EQB300
When I took my '23 EQB300 for the update, dealer told me they would not apply it since they did not believe it to be stable. And they would reach out when they have a stable update. That's been close to 3 months and nothing back from them.
As I've been writing for months in the forums, most problematic car I've ever had. Mercedes should have lemoned it but lemon law attorney said they found a loophole out of lemon law. 11 months 10 days left on the lease, but who;s counting?
Old Sep 10, 2025 | 01:56 PM
cadetdrivr's Avatar
2014 GL350
FWIW, there is now a second battery recall involving 2022-2023 EQBs that requires a complete high voltage battery replacement.
Just received a letter from MB for our ’23 350 and they have no information about timeline for repairs.
File Type: pdf
Old Sep 10, 2025 | 07:21 PM
abhansali's Avatar
I just put my VIN in at NHTSA website and looks like I'm affected. Probably will get letter in the mail here soon. I wonder how long it will take to get this replacement battery?
Old Sep 10, 2025 | 08:16 PM
  #32
cadetdrivr's Avatar
2014 GL350
Given the low-volume of the EQB battery, current EQB residual values, and the significant expense of battery replacement (including labor), I’m gonna suspect that MB may simply scrap our EQB when it comes off lease in a few months.
Might just be cheaper to offer buybacks to current owners as well.
Looking at the NHTSA info, it looks like there should be additional info sent to owners around September 23.
Old Sep 11, 2025 | 06:26 AM
  #33
nsoltz's Avatar
2023 EQB300
I suspect my EQB will be headed to the car crusher when it comes off lease in July '26. Still nothing from my dealer about the first battery management software update and I would doubt the battery replaacement could be done in a timely manner, if at all.
Old Sep 11, 2025 | 06:38 PM
  #34
ehildum's Avatar
2024 EQE Sedan
First super charge at EA after software update and we are getting 35kw charging at a 350kw charger. It could be the charger but curious if anyone else is getting this level of reduced charging speed.
The charge rate will start high, then drop as the battery charges. Also, if the battery is hot or cold, the rate will be lower. That is if the charger is working correctly. The EA chargers will reduce charge rates if the cable or charger is hot. I used one charger that for a couple of months had a bad cable cooling pump, it would start at full power, then drop to about 35kW shortly as the cable warmed up.
You are going to get your max charge rate at the most discharged state, then the charge rate drop a bit at first, then decline slowly as you approach 80%. After 80%, the charge rate will decline rapidly to almost nothing as the battery approaches 100%. That last 20% may take as much or more time than charging from 20% to 80%. From a battery life and charge time perspective, you should limit your charging to 80%.
Also, you don't have to fully charge the battery when you charge. If the car is at 70% and you need to go, just do so. This especially matters if you are using the two year free charging. Just charge for 30 minutes and leave. You don't need to "fill" the tank the way you usually would at a gas station. I will admit that "fill" the battery mindset is hard to get rid of, but it will save you time (and money) when you get rid of it.
