EQE SUV (X294) Forum for Discussion of EQE SUV
Brake Job Interval?
Old Jul 28, 2024 | 11:21 PM
Scott Schmidt's Avatar
GLS 450 (2022), EQE SUV 350 (2025). GLS 450 (2007)
Brake Job Interval?
Hi folks. I'm taking delivery of a new 350 EQE SUV next month and was looking at the maintenance schedule on the MB website. It doesn't show anything at an interval longer than 20K miles, and there's nothing shown for brakes aside from fluid change. Does anyone know what I should expect with regards to brake replacement intervals? I know it's a new model and most people won't have done this yet, but maybe someone has some equivalent experience.
Old Jul 29, 2024 | 05:24 AM
ygmn's Avatar
2015 E400 Sedan
I have never seen a manufacturer list mileage of when to replace brakes pads etc.
MB has a sensor that will warn you on dash your pads need changing which is way more than most other manufacturers provide which tends to be a clip that squeals.
SO drive it until sensor goes off or when you get any work done with a wheel off have pad thickness inspected.
Old Jul 29, 2024 | 08:14 AM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
Unless you ride the brakes very hard, it's unlikely you'll have to replace the brakes before 100k miles if not 200k or later. Maximize regen, and brakes may last the life of the car. All you need is fluid changes every 2 years as the fluid is hygroscopic. Every 20k miles just in case. I'm sure they'll check pad and rotor thickness during the service interval and give you plenty of notice.
Old Jul 29, 2024 | 08:16 AM
Thanks again for the reply.
Old Jul 29, 2024 | 09:16 AM
streborx's Avatar
Top Answer: 1
G550
Brake pad and rotor wear are mostly dependent on driving habits and frequency of use, not mileage or elapsed time. Best guess is your experience with other cars, unless you adopt a more aggressive driving style with your new MB.
Old Jul 29, 2024 | 09:29 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
https://www.google.com/search?q=ev+brake+pad+wear
I wouldn't worry about it.
