EQE SUV (X294) Forum for Discussion of EQE SUV
12 Volt Battery longevity?
Old Aug 13, 2024 | 10:40 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
How long will the 12 volt Battery last? Typically in ICE cars, the battery needs to be replaced after 3-4 years. Same here?
Old Aug 14, 2024 | 12:51 AM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
EV 12V batteries experience no cranking load, and the DC-DC converter can run any time, so I suspect the 12V battery will be in its happy place much longer. Less wear and tear, so maybe a bit longer life out of it?
Old Aug 14, 2024 | 01:27 AM
superswiss's Avatar
2019 C63CS
That depends on the type of battery. 12V batteries comes as lead acid, AGM and lithium. The latter two are what's used most commonly these days. AGM more so than lithium. Not sure what the EQE uses. AGM is 4-7 years and lithium 5-10 years. How it's being charged is part of it, but also the environment. Batteries don't like hot temperatures for example.
Old Aug 14, 2024 | 06:28 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
With less heat and probably less vibration, one would think this would be a good setup for the battery to last a long time. About a year ago, I pulled a 10 year old OEM battery out of my 2008 CL that was still functioning. FWIW, my Jaguar I Pace went through two in four years of ownership, but that car had lots of problems.
Old Aug 14, 2024 | 07:18 AM
EQE uses lead-acid AGM. But because it stays near fully charged and doesn't get very strong loads, I'd suspect it'll last a while. But we'll see!
