EQE SUV (X294) Forum for Discussion of EQE SUV
Check Coolant Warning!
Old Nov 30, 2024 | 01:38 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
I got this warning this AM on my AMG EQEX4 this morning. The overnight temperatures had dropped outside to 28 degrees. I took the car to my dealer who topped off both coolant reservoirs under the hood. I've never seen what things lurk under there so I was surprised at how neat everything was. There was a large plastic cover that had to be removed in order to access the tanks. There were no leaks discovered at this time.
Old Nov 30, 2024 | 01:45 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
Happened on my dad's X294 and on ours this summer. Looks like the coolant was filled ever so slightly low (about 1cm below the marker). I bought some MB coolant and topped it off, hasn't returned. Simple fix!
Old Nov 30, 2024 | 01:59 PM
HBerman's Avatar
I had the low coolant on my 2021 E63S after 2 years. I wonder where the coolant goes? Evaporation through the reservoirs?
Old Nov 30, 2024 | 04:21 PM
I think in the case of the EQEs, it doesn't really go anywhere, there may be some very small voids that are just not possible to fill in a short amount of time. The EQEs also have red pressure regulating caps that prevent the two expansion tanks from going out of sync, it's theoretically possible that in high pressure situations, some coolant is lost there due to slight evaporation. There also may be some hygroscopic nature of the seals used in the system, so I suspect some may go there too, if that's the case. Overall though, I think it'll be a logarithmic plot, where after the initial refill you probably won't encounter it again.
