EQE SUV (X294) Forum for Discussion of EQE SUV
Another OBD2 connection help request
Old Feb 9, 2026 | 09:31 AM
Typical Guest's Avatar
2023 EQE 350+ SUV
Hi. I had my OBD Scanner tool (Veepeak OBD2 ELM327) successfully connected to my EQB. Noe it is not working on the EQE. Any Help here available? Is the EQE protected? The Veepeak Website says it is compatible with all cars from X Date. So it should be able to find the Connection. I started the connection and it failed in the EQA/EQB setting. 3/3 Attempts- failure message. in the standard Mercedes Setting it went to 2 Attempts and then to 17/17 different Checks. Failure.
What setting do I have to use as there are only 2 Settings for EV’s and the standard first in Row Setting as suggested by the APP to use if the specific Car is not listed.
I just charged my Car over night at home to 80% and wanted to check the Battery Temperature.
Thanks for Your helping input.
Old Feb 9, 2026 | 10:37 AM
trigital's Avatar
W213 All-terrain
EQE is Star3 configuration, not compatible with generic OBD scanners without security certificates.
Old Feb 10, 2026 | 07:09 AM
2023 EQE 350+ SUV
Hi,
Is there any OBD Scanner as simple as the one I have with this Star 3 Certificate? I read about the 30thousand Dollar ones but don’t need that.
Old Feb 10, 2026 | 07:31 AM
ua549's Avatar
Look at this page.
Amazon.com : Mercedes Star 3 Diagnostic Tools Amazon.com : Mercedes Star 3 Diagnostic Tools
Old Feb 11, 2026 | 07:36 AM
2023 EQE 350+ SUV
Hi,
Thanks but there is nothing on Amazon that I can see specifically mentioning this Star3 system certificate or coding. Is nobody here already using one in their newer Vehicle Type that is as simple to use as the regular OBD2 Scanner? I loved the way one is able to make your own screen with the display selections from all these sensors it detects and reads. I’m not so sure if these other scanners do this too. I don’t need a scanner tool to check Diagnostic error codes to reset. Just the readout of my EQE inner workings and the EV Battery System. I don’t see this in the vast and confusing Amazon Product lineup.
Thank You.
Old Feb 11, 2026 | 11:39 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
I have an SDS and cannot talk to my EQEs, it requires an active login to Xentry's online portal. So, even with the right equipment, I can't talk to my cars at all. The cars all use FlexRay, which is secured and requires online authentication in the case of these cars.
Old Feb 12, 2026 | 07:44 AM
ua549's Avatar
MB has moved much of what used to be one time or free services to subscription services to provide a continuing revenue stream.
Old Feb 12, 2026 | 01:53 PM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
I know my Foxwell 510 does not work. I can't even get my Xentry system to work with the most recent hard drive update. I think MB has locked us out until someone figures out a work around, if ever.
Old Feb 12, 2026 | 02:27 PM
trigital's Avatar
W213 All-terrain
For diagnosis with Xentry, a simple security certificate can be loaded and everything will start for Star3 cars ( with a 10$ Enet cable)
