EQE (V295) Sedan Upcoming
Acceleration fee
Old Jun 19, 2023 | 12:02 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
Originally Posted by Sportstick
This is more of a question than statement. My understanding is that the 350 all wheel drive has a smaller battery and the shortest range of all three versions. Wouldn't adding the acceleration option take that low number even lower, while the 500 has almost the best range of the three (second to rear wheel 350). Starting from a rear wheel might result in not as low a range, but doesn't that also reduce torque or does this option somehow restore the equivalent of the missing second motor? Decisions, decisions!
They all have the same 90.6 kWh battery. EQE350V4 has longer range than EQE500V4. Difference is in motor speed controllers and potentially the motors.
In retrospect - we may be talking about two different vehicles. For some reason the SUV range estimates look different (in vehicle model order) than the sedan's range estimates.
Old Jun 19, 2023 | 01:34 PM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
It's a 100 kWh battery, 90.6 "usable" and 9.4 buffer. In any case, this is a thread about acceleration so range be damned! 633 lb-ft torque and only 400 HP? Somethang don't add up... I can actually feel the limiter kicking in. It's like all that "oomph" it has off the line just suddenly drains out.
Old Jun 19, 2023 | 02:09 PM
shakoomakoo's Avatar
2025 E53 AMG & 2024 EQS SUV
The 500V4 is still faster than the 350V4 even when you unlock the acceleration. The 0-60, in multiple videos, is 3.8 sec on the 500.
The range of the 350V4 is better than the 500V4. Now the question is thr 500 worth the extra money if the 350 is 4.5 sec with acceleration fee?
Old Jun 19, 2023 | 04:33 PM
Sportstick's Avatar
Another round of ICE
I found this model comparison in the 2023 Order Guide. I was referring to these battery sizes, but I'm not sure how significant this is. But, it does seem the 350 X4 with the acceleration package would have the shortest range by a greater margin than it now does?
​​​​​​EQE350X 
Performance & Handling
● Adjustable Regenerative Braking with Steering Wheel Paddles
● 90.6 kWh High Voltage Battery
● DYNAMIC SELECT (B59)
● 170 kW DC Fast Charging
EQE350X4 
● 89 kWh High Voltage Battery
EQE500X4 
● AMG Line Exterior Package
Old Jun 19, 2023 | 04:36 PM
Sportstick's Avatar
The MB order guide has different information. The 500 wins by 16 miles.
EQE350X4 
Powertrain
Powertrain Dual Permanently Synchronous Electric Motors with 215 kW Total Output
Power 288 Horsepower
Torque 564 lb-ft of Torque
Interior Dimensions
Head Room Front 39.5 in
Leg Room, Driver 40.6 in
Elbow Room, Front TBD
Hip Room, Front 56.5 in
Shoulder Room, Front 58.9 in
Head Room Rear 39.4 in
Leg Room, Rear 40.6 in
Elbow Room, Rear TBD
Shoulder Room, Rear TBD
Drivetrain and Battery
Drive Configuration 4MATIC All-Wheel Drive
Battery Size 89 kWh Lithium-Ion Battery
Suspension Comfort Suspension w/ Selective Damping
Number of High-Voltage Modules 10
AC Charging Capacity (240V) 9.6 kW
AC Charging Time (240V) 9.5 hours (10-100% SOC) 10.75h (0-100% SOC)
DC Fast Charging Capacity 170 kW
DC Fast Charging Time 32 minutes (10-80%)
Range & Efficiency
Efficiency Figures 42 kWh / 100mi
City/Hwy MPGe 82 city / 79 hwy / 81 comb MPGe
EPA-Certified Range 253 (w/ All-Season Tires)
EQE500X4 
Powertrain
Powertrain Dual Permanently Synchronous Electric Motors with 300 kW Output
Power 402 Horsepower
Torque 633 lb-ft of Torque
Interior Dimensions
Battery Size 90.6 kWh Lithium-Ion Battery
Range & Efficiency
Efficiency Figures 38 kWh / 100 mi
City/Hwy MPGe 91 city / 86 hwy / 89 comb MPGe
EPA-Certified Range 269 mi
Old Jun 19, 2023 | 11:32 PM
Well, if the 500 has more power and more range why would anyone buy the 350?
Old Jun 19, 2023 | 11:53 PM
  #32
Doesn't matter because range when doing 0-60 runs is 113 miles. And I didn't just make that number up.
Anywhosies, point is we all want MOAR POWAH! I paid EQS 450 money for my EQE 500 and no acceleration increase for me. They're like the EV version of Seinfeld's soup ****.
Old Jun 20, 2023 | 12:21 AM
  #33
nosnoop's Avatar
535
The different battery sizes are due to different battery supplies sources.
It would vary depending on which suppliers on that batch, they consider the difference insignificant.
The range is hard to compare as they use different tires for EPA testing!
The longer range is done using optimized summer tire, while the other uses all season tires.
Anyways, the acceleration increase was stated as not having any effect on the range.
Old Jun 20, 2023 | 12:23 AM
  #34
nosnoop's Avatar
535
The acceleration increase for the 350 is only possible because it was intentionally crippled in the first place.
There is no acceleration increase for 500 because it is already as fast as it was designed. No intentional crippling, no acceleration increase.
Old Jun 20, 2023 | 12:48 AM
  #35
They sold me the AMG look with my fancy 21" AMG rims and now I want AMG fast, as the EQE 500 was designed to be. It's just a more grown-up version without all the childish spaceship noises the EQE AMG makes.
Old Jun 20, 2023 | 07:09 AM
  #36
W205C43PFL's Avatar
Yup just like phones or any battery powered device, kind of like the lottery, if you got the one with the higher actual capacity vs rated or designed then good for you.
Old Jul 16, 2023 | 04:54 PM
  #37
So, I did some more "empirical testing" today, and charged up my battery to 96% (highest I've ever charged) before doing a couple more pulls. It definitely seems that the inverters are power-limited, independently of the state of charge. Granted, it was a bit hotter outside than last test, but I kept the AC off just to remove any additional heat making into the cooling loop. Fastest 0-60 pull was 4.49 seconds at 95% charge, last time I tried with 72% I got 4.50. Including both directions, right at 4.56 seconds 0-60 average. So, it looks like state of charge isn't limiting things here, at least in the upper range of the battery, which is good! I'd also put on 2500 more miles on the car. The 0.01 second difference is, I'm sure, within the margin of error for the race computer, so as near as makes no difference, it's the same.
Old Jul 18, 2023 | 08:31 AM
  #38
W205C43PFL's Avatar
I see. Thanks for the update.
Old Jul 22, 2023 | 01:03 PM
  #39
mbdocsms's Avatar
2021350GLE
First month free trial
Just subscribed and it’s a free first month… trial period. Then $60 a month. They know that once you try it you’ll be hooked !!! It’s awesome but I wish it would be included especially since there is no cost to MB.
Old Jul 24, 2023 | 07:05 PM
  #40
W205C43PFL's Avatar
Well, they are argue the cost is additional wear and tear of the motors leading to potential higher/more frequent repair cost under warranty but it is probably minimal.
How do you find it so far?
Old Nov 13, 2023 | 11:36 AM
  #41
BTW, though its a European-only thing, if you look at the specs for the AMG 43 variant, it has an IDENTICAL 633 ftlb (858 nm to be exact) torque as my 500. The difference is it has 469 HP and my 500 has 402 HP. So I'm not so sure the 43 is the "detuned" one. I mean, it's not like AMG actually does anything to the motors. It's all just software.
Old Nov 13, 2023 | 11:38 AM
  #42
The 63s have custom motors. If you look at the kW rating, they are different. However, all the other cars have the same motors, at least from the kW power rating. The differences are in the traction inverters and to some extent the cooling.
Old Dec 11, 2023 | 09:13 AM
  #43
ngiovas's Avatar
EQE SUV - 350 4Matic
I'm just curious to find out from those who purchased the acceleration package if it impacted your average range. Obviously, you will use more battery if you are rapidly accelerating all of the time, but for normal daily driving, does it impact the range? Someone commented that it isn't supposed to impact range, but I am curious to find out what everyone's actual experience is. I'm mostly concerned what the impact will be for longer trips where I may need the full range. If I drive in eco mode, can I expect a similar range to a EQE without the acceleration package?
Old Dec 11, 2023 | 12:36 PM
  #44
Wont' have any effect whatsoever unless you push the accelerator to the point where the boost kicks in. In other words, if you keep your power application to below 80%, you won't be engaging the boost at all. I like to extend my range, so I drive pretty gently for most cases unless I need the boost. Most of my acceleration is between 20-30% power. So, the boost won't even activate at those power ratings, so it won't affect your range. When in warmer weather in mixed driving, I can get about 268 Wh/mi. Most 70 MPH road trips get me about 289 Wh/mi or so, sometimes higher, sometimes lower. Of course, your mileage may vary. But that's still 3.5-3.6 mi/kWh, so the boost hasn't dropped it any. Predicted range in warmer weather is about 353 miles (doubtful you'd fully get that range, but 330 is not at all out of the question and is in line with Consumer Reports' findings) even with the boost upgrade.
Last comparison on this, my dad's EQE350X4 SUV doesn't have the acceleration increase, but his average economy is still lower than my sedan's that does have the acceleration increase. That's to be expected because the SUV is less aerodynamic than the sedan (even though he has a front-axle DCU). If acceleration boost were impacting it, I'd expect worse performance, but that's not the case.
Old Dec 13, 2023 | 12:19 AM
  #45
If itt impacts the range it’s not noticeable. There are other factors that impact range way more like weather, tires, driving habits and climate control. I would not worry about range when purchasing this service.
Old Dec 13, 2023 | 10:34 AM
  #46
admannj's Avatar
EQE 350 4Matic Sedan and SUV
I went through with the purchase and am happy with the noticeable increase in horsepower. I have had it for about a month and have not seen any dramatic effect on range.
