Range
Tesla grossly overstates their range. Based on my calculations in two different Model S, their predicted range was based on 275W/mi, while my driving averaged around 310-315.
The BMW i3 uses an algorithm based on the last 30 miles of driving, with a deduction whenever the air conditioning is on. As a result the estimated range varies quite a bit. It's a much smaller / lighter car (though with horrible aerodynamics) and averages more like 230 W/mi (4.2 mi/kWh)
The EQE seems to be using some sort of algorithm to predict range based on recent driving experience as opposed to a constant like Tesla. On a recent road trip which was mostly freeway driving with the air conditioning on, I was pleasantly surprised to see consumption in the 280-290 W/mi range. On the return trip of 287 miles, including a descent from 4,000' to sea level (with ups/downs), AC on and freeway driving, I averaged 270 W/mi (or 3.7m/kWh).
Over 10,000 miles of driving I've averaged 3.2 mpkWh or 312 Wh/mi which puts it on par with the Tesla Model S. I think this means that Tesla has no advantage in engine / systems efficiency.
FWIW, all of the above is using strong regen.
Do you have creep mode activated or deactivated, while in strong recuperation mode?
