Easy entrance and exit
Subscribe
Jun 16, 2025 | 01:04 PM
On EQE, I have two drivers. No 1 sets seat nearly back and I activated easy in and out and seat is back as I shut off and open door. No 2 is way up and in memory 2. Easy in out also activated, but it won't move back when turning off. If I get in after No 2. As driver no 1. Seat is up, memory buttons won't work. Etc. A pain until I can select no 1 on screen.
I see some people have seat tied to remote, no such option in my profiles. Dealer is clueless as usual
So question is. How to set easy in and out seat as t position for driver no2 without messing up desired seat in memory 2?
Reply 0
Jun 16, 2025 | 08:10 PM
The Home > Settings > Vehicle > Easy entry and exit setting is global rather than associated with a specific profile, i.e., when set it should operate for both profiles. That is how it works in my EQE SUV. When the vehicle is turned off by either driver the seat moves to the common entry/exit position.
Reply 0
Jun 17, 2025 | 12:58 PM
My no 1 way back driver moves all the way back. The No 2 way up close seat does move but not as far as No 1. Might delete no 2 and start over to see if it works.
Also no settings to link key fob to profile as ive seen on Suvs. Maybe my 20k service can update software.
Reply 0
Jun 17, 2025 | 07:17 PM
Quote: Also no settings to link key fob to profile as ive seen on Suvs. Maybe my 20k service can update software.
The link key fob is a 2024+ model feature.
Reply 0
Jun 20, 2025 | 01:16 PM
Quote: The Home > Settings > Vehicle > Easy entry and exit setting is global rather than associated with a specific profile, i.e., when set it should operate for both profiles. That is how it works in my EQE SUV. When the vehicle is turned off by either driver the seat moves to the common entry/exit position.
I am not sure that is correct. I needed to set it and save it in the profile for each driver in my car for it to work reliably.
Reply 0
Jun 20, 2025 | 07:02 PM
What did you set, where you want seat when exit and where save, in a memory? If memory, where save actual desired seat position ? I must have saved something right for Number 1 driver, but seat is OK for number 2, but exit moves only 1/2 inch instead of Way back like no 1. I put seat position for number 1 in memory 1 and number 2 in memory 2 and never purposely saved any of them someplace for exit position.
Reply 0
Dec 8, 2025 | 11:14 PM
My car is at the dealer for service for these two items plus the fogging passenger headlight in my other post
we shall see. Will update this thread
Reply 0
Subscribe
Currently Active Users (1)
