ABRP - Upvote our EQS SUV
ABRP (A Better Route Planner) is a great tool to plan road trips. Our EQS SUV's have not been added yet. I added then to Upvote and would appreciate if this community could go give them a thumbs up so we can get them added to the ABRP tool. Also check out ABRP it's a great resource for planning any type of trip. For now I've been using use the EQS Sedan as a basis, but it's not as accurate as having our true WTLP and vehicle data added.
580:
https://abrp.upvoty.com/b/add-a-vehi...uv-580-4matic/
450:
https://abrp.upvoty.com/b/add-a-vehi...suv-450-4matic
580:
450:
mb_star (10-21-2022)
Voted. I noticed there is now a “EQS 450 4Matic” but it doesn’t indicate if it’s the SUV… the Wh/mi is a bit low so likely not….
Thanks for getting the ball rolling on this. I use ABRP all the time, great tool.
Thanks Mprog , keep the upvotes coming , really would help us all that use this tool. Takes 5 seconds to click the links above and upvote.
Looks like we will get our model soon in ABRP, Anyone have a charge video yet? We need this data so feel free to add replies if you have easy access and I will submit to ABRP:
Usable Battery Capacity
- Range (WLTP is preferred)
- Weight
- Dimensions (Height, Width, Length)
- Coefficient of Drag
- Coefficient of Rolling Resistance
We can build a model based on only a partial set of these, but the more data you can provide the better the model will be. For charging, at least some of the following data is needed:
- Peak Charge Power
- Charge Time (including start/end %)
- Plot of Power vs SoC %
A video of a charging session from low to high SoC would also work quite well.
- Weight
- Peak Charge Power
