3200 miles in six weeks
I love driving the EQS SUV so much that I seem to be making any excuse to take a trip. After 3200 miles I am averaging 2.4 mpkWh with an average speed of 32 mph. I believe the 32 mph number is lower than actual as I have spent several hours in the parked car exploring features. I am somewhat disappointed in the 2.4 mpkWh since I was getting 3.1 in the Taycan CT. The difference is most likely due to the 1000 pounds in extra weight and increased frontal area of the EQS. On a positive note, the EQS SUV is a lot less stressful to take on the road since DC charging works with no drama. With the Taycan a phone call to EA with long hold times was often required to get charging to start. I do still have to deal with the high percentage of out-of-service chargers at EA, but at least I do not have to spend a half hour on the phone with EA support.
I normally use Intelligent Recuperation (after remembering to activate it). I find myself stopping a little further away from the car in front of me so as not to activate the "HOLD" feature when the "READY" light comes on after the full stop. I prefer this approach since resuming driving starts out more smoothly, when "HOLD" does not have to be overcome.
Here are a few things on my software upgrade wish list:
1) MBUX allows you to specify a desired SoC at your destination. For away-from-home destinations I like this to be around 50% so that I can make some local trips around the destination without immediately requiring a charge. But when my destination is set to HOME on the return trip, I am okay arriving with an SoC of 10%. If you forget to lower the setting when returning home, you will be routed to DC chargers even though you know that there is sufficient charge to make it home. If you skip the recommended charger, then MBUX will route to the next available charger to "help" you reach the specified SoC at your HOME destination. This can increase the length of the return trip since none of the suggested chargers will be exactly on the shortest route home. The enhancement I would like to see is the option to set a lower SoC when the destination is HOME.
2) The amenities at various charging stops vary widely. In general I prefer charging at a Sheetz gas station over a Walmart parking lot. The restrooms are closer, windshield squeegees are available, and they are usually not as far off the route. I would like to be able to designate a charging station as preferred or alternatively as one to avoid based upon previous experience with chargers on a particular route.
3) Planning a trip from the car GPS is not as easy as planning one from PlugShare or Google Maps, but it should be. I would like to be able to designate the expected SoC at the start of the trip rather than use the current SoC when planning the trip a day or two prior to the actual travel day. Not being able to specify a starting SoC means that an early charging stop will be added to a trip based upon the current SoC. Then the additional recommended stops will be out of "phase" with what actually makes sense when starting out with 100% SoC. Another feature I would like to see is alternative routes being suggested when planning a trip. PlugShare and Google Maps almost always suggest two or three alternative routes rather than just the shortest route.
I had originally planned to order an EQE SUV, but with the new EV tax credit eligibility rules I rationalized getting an EQS SUV off the dealer lot. The EQS SUV is the third EV I have owned since 2020. The obscene trade-in values made it easy to change EVs in the last couple of years. The current collapse of used car prices (at least in the NE) is probably going to mean holding onto the EQS SUV until the MMA and MB.EA architectures are launched.
