EQS SUV Forum for Discussion of EQS SUV
Anyone Know How To Remove These Inserts?
Old Dec 12, 2022 | 07:39 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Just curious as I have tried gently to pry one off but don’t want to break anything.
Old Dec 12, 2022 | 07:45 PM
LAZARU5's Avatar
2025 E53 Hybrid
Have you tried removing the wheels and using a plastic trim removal from the backside of the wheels? That would have less chance of damaging the outer surface.
Old Dec 12, 2022 | 08:13 PM
I might try that and by taking a wheel off see if there are any clips on the back side. Just been too busy lately to get the Jack and tools out….
LasVegas_89135's Avatar
2023 Mercedes ESQ SUV 580 ● 2021 Volvo XC40 Recharge
By the way, I completely agree with you that the RWO wheels would look much better without those inserts. I had originally placed my order with them as my wheel option. But after a closer look, and with nobody at the dealership knowing if the inserts were removable, I decided to have the order updated to the RWX wheels. (February delivery)
Old Dec 12, 2022 | 08:58 PM
If you blow the photo up you can see a hole in each insert near the hub. When a flashlight is used to look into the tunnel of each hole it is solid at the end but there is a hole perpendicular to the tunnel. I wonder if there is a special tool that is “L” shaped to slide down the tunnel then insert perpendicularly to release something. Otherwise I see no use for the hole/tunnel.
I was just hoping someone else had already removed these and could elaborate here.
Old Dec 12, 2022 | 09:57 PM
LAZARU5's Avatar
2025 E53 Hybrid
I doubt if there is anything to release in the hole. It's more likely that a stiff wire hook can clip into the hole and be used to pull that inner corner out. Have you looked for a tool somewhere in the car?
Old Dec 12, 2022 | 10:12 PM
LAZARU5's Avatar
2025 E53 Hybrid
Old Dec 12, 2022 | 10:24 PM
There is nothing I have found but can easily cobble something up from the hundreds of spare Allen wrenches I have around. Can grind one down a correct shape and clamp on a vice grip as a handle.
Old Dec 13, 2022 | 06:21 AM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
I believe I saw it mentioned somewhere in one of the zillion reviews out there that these inserts had some aerodynamic benefit. If they do, I suspect it must be very small...
Old Dec 13, 2022 | 12:36 PM
I took a look this morning and the inserts are held on the inside of the hub with Allen type machine screws. The tires will have to be removed in order to take the inserts off properly. A project for another day! At least I know the answer now.
Old Dec 14, 2022 | 02:58 PM
Mprog's Avatar
EQS
I didn't think I'd like these wheels from pictures I saw, but in person I think they look fantastic (inserts included) !
Old Dec 14, 2022 | 03:45 PM
Close up photos don’t do them justice. From a distance they look great to me and folks easily recognize the SUV as a EV.
Old Apr 16, 2024 | 02:38 PM
Binaryman's Avatar
EQE500
did you ever remove the inserts? how do the wheels look without the inserts?
Old Apr 16, 2024 | 04:27 PM
No, Never got around to it. Since they are fastened and removed from the back side each wheel has to be removed and at 70 years old projects like these are no longer done just for the fun of it! 😊
Old Apr 16, 2024 | 05:14 PM
Binaryman's Avatar
EQE500
Thank you for the update. I may try to remove these and post a pic.
Old Jun 11, 2024 | 01:05 PM
hjcsdca's Avatar
2023 Mercedes-Benz EQE350 SUV
Any chance you got to try this removal? Curious for my EQE SUV as well...
