Jacking up the EQS SUV for a wheel change
https://www.tirerack.com/tires/tires...ar=275%2F45-21
I have noticed that the front tires are wearing down much faster than the rear tires...
Just removed the wheel and dropped it off at discount tire for the tire swap. I also discovered that the rear brake pad is probably half way gone already, considering I only have 4k miles from July. The rear wheels also have a lot more brake dust than the front.
Has anyone replaced the brake pads on his/her EQS SUV yet?
thanks
The American wife's AMG E53 with 90k miles is back to what I consider to get normal with about 1 mm left rear pads using the old rule of thumb to change pads when the friction material thickness matches the steel backing plate.
https://youtu.be/OQkdvi55woA?si=RCbgO1yRk_k-lzYW
many times, when changing lane without signal the steering wheel jerk the car back into its lane. I tried to drive with strong regenerative for one week without the use of the brake and my wheel still get covered in brake dust, so something is going on back there.
