Digital Light Activation
is this feature useful? I see mixed reviews on the forum.
Also current price is $460 for this coding job.. was the price cheaper during thanks giving?
It was definitely a good value for the 2019 at around $250. Not so sure at the 2x price for the same feature on the EQS but I'm happy to have it, all of the projection features were already present.
Request:
Please check Xentry / VeDoc for any open campaigns or service measures applicable to my vehicle, specifically related to the Digital Light headlamp system (Option code LG2 / 641).
I am requesting:
- Verification of any open campaigns such as Service Campaign 2023070020 – “Update Software for Various Control Units” (released August 22, 2023).
- Execution of any software updates and SCN coding for the headlamp control units (N71/1 and N71/2) to enable Adaptive Highbeam Assist PLUS / Adaptive Driving Beam functionality now permitted in the U.S. under updated NHTSA FMVSS 108 rules.
- Confirmation that the latest approved software for the Digital Light system is installed.
Notes:
- This is a software activation for existing factory-installed hardware, not a retrofit.
- The goal is to enable the beam-shaping function inherent to the Digital Light system, where legal.
- Relevant terms in Mercedes documentation: LG2 – DIGITAL LIGHT with projection function, Adaptive Highbeam Assist PLUS, ADB.
Will the dealer know about it? Depends on how much they look for it. Chances are, your dealer doesn't give two shi...fts about some headlight mod unless that mod can be traced or tied to the failure of a component you're trying to get worked on under warranty.
- FMVSS 108 finally permits ADB systems, but with stricter interpretations:
- The system must switch between defined “beam patterns” rather than continuously sculpting light.
- It must meet both legacy high-beam and low-beam photometric test points, even while adaptive.
- U.S. standards prioritize predictability and legacy test compliance over maximum illumination.
- This has forced automakers to either:
- Tone down their European ADB tech in U.S. cars, or
- Ship the same hardware but with different software logic — so the beam shaping is less dynamic and sometimes more conservative than in Europe.
Key Differences in Practice
- Europe: Smooth, surgical “carve-outs” around other vehicles. You almost always drive with adaptive high beams on.
- U.S.: Step-like transitions, more conservative cutoffs, more frequent full dimming to low beams. The system often feels less “magical” than its European counterpart.
- Reason: U.S. law requires compliance with rigid photometric test grids designed for old sealed-beam headlights, while Europe wrote rules from the ground up for adaptive LED and laser systems.
